Need help with removing the radiator......
I'm a long time contributor on the Aerostar forum, and since my 99 Mountaineer 5.0 has not given me any trouble I have not posted here at all. Now I need a little guidance.
I am replacing the radiator and ran into a problem while removing it. I have everything disconnected, i.e. hoses and tranny cooler lines. I have removed the three mounting bolts, but now I can see that the A/C condensor is somehow attached to the radiator. Can someone please give me some help as to how to separate these two items?
Thanks,
Klaus Cook
Houston, Texas
REMOVAL AND INSTALLATION
Drain cooling system.
Remove air cleaner outlet tube.
Remove rubber radiator overflow hose from radiator and position aside.
Use fan clutch wrench to remove fan clutch from water pump pulley.
Remove upper fan shroud screws. Lift fan shroud from lower retaining clips.
Remove fan shroud and fan blade.
Loosen upper and lower hose clamps at radiator and remove upper and lower radiator hoses.
On models with automatic transmission, disconnect transmission cooler lines at radiator and remove transmission cooler tube support bracket from bottom flange of radiator.
On all models, unclip A/C condenser core from radiator.
Remove A/C condenser to radiator bolt.
Remove two radiator upper screws.
Separate radiator from A/C condenser core and remove.
Remove radiator lower support rubber insulators.
Reverse procedure to install.
