No Power
Old Oct 3, 2005 | 06:11 AM
defster99's Avatar
defster99
No Power
Hi All!
I have a 1985 F-150 4.9L inline six 4spd man. The thing died on me the other week while driving on the turnpike. Popped the hood and noticed that the exhaust manifold was glowing red. It wouldn't start up again so I had it towed home. I did a compression test and got a reading of about 128psi even on all cyl. I replaced the fuel pump because at the time it died I noticed that the fuel pump was leaking. The truck now starts but it has a very low idle (150-250rpm)and absoulutly no power to get out of it's own way. Thought it may have been a clogged catalytic converter so I unbolted the exhaust pipe where it meets the exhaust manifold. Still no power! Is it possible that the crank and cam timing might have skipped a tooth? Has anyone ever experienced a condition like this?
Thanks for any leads!
Old Oct 3, 2005 | 06:28 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 3, 2005 | 07:34 AM
Holmesuser01's Avatar
Holmesuser01
Being that it is 2 gears, I doubt that the crank/cam gears are the problem. Red hot exhaust? Possible that the truck just leaned out? Is yours fuel injected?
Old Oct 3, 2005 | 08:55 AM
fordborn's Avatar
fordborn
Thread moved to "Inline Six, 200, 250, 4.9/300" technical forum. Should receive more responses to your question here.
Old Oct 3, 2005 | 09:26 AM
Silver Streak's Avatar
Silver Streak
Sounds like a fuel delivery problem to me.
Old Oct 3, 2005 | 10:49 AM
quicklook2's Avatar
quicklook2
[QUOTE=defster99
[/QUOTE]
where was the fuel pump leaking at? most of it is in the tank. do you have a clogged fuel line or return line?
Old Oct 3, 2005 | 11:57 AM
defster99's Avatar
defster99
The fuel pump is a non electric manaul type located at the left front side of the block.
Old Oct 3, 2005 | 12:15 PM
quicklook2's Avatar
quicklook2
oops, sorry!
Old Oct 3, 2005 | 06:02 PM
Holmesuser01
How long since you rebuilt your carburetor? Sounds to me like this might be your problem.
Old Oct 3, 2005 | 07:59 PM
defster99's Avatar
defster99
I'll take a look at that. Maybe the accelerator pump is defective?
Old Oct 3, 2005 | 10:34 PM
Holmesuser01
I think its plugged up. My truck overheated on the highway one and lost power. I had the carb rebuilt and it was good to go.
jbancroft
Jul 10, 2014 09:12 AM
Matthew521
1978 - 1996 Big Bronco
Mar 6, 2012 08:03 PM
Matthew521
Mar 6, 2012 02:13 AM
ech0sh4y
50
Dec 30, 2007 01:28 PM
the kid
Nov 24, 2006 05:29 AM
