96 Explorer message center computer
Old Oct 2, 2005 | 04:24 PM
srwells's Avatar
srwells
Question 96 Explorer message center computer
96 Explorer message center (console) went crazy - flashing, beeping. Dealer says "message center indicator" died. I had him disconnect it.
Later, during service, was told I had to have new "computer" to get rear center brake light working.
Are the brake light and message center indicator linked?
If not, what parts to I need for each repair? I have a part number for the message center indicator, but have been unable to match it through any parts dealer.
Old Oct 3, 2005 | 10:04 AM
FTE Ken's Avatar
FTE Ken
Moved to proper forum. Thisn't an aftermarket chip/tuner question.
Old Oct 3, 2005 | 01:09 PM
87 XLT's Avatar
87 XLT
Sounds bogus to me, but take a quick look at a wiring diagram.
On a 97 the 3 brake lights are simply spliced to the brake light switch.
Edit
Yours might be diferent but on the 97 theres also a fuse for the center brake light. Have you checked that fuse?
Old Oct 4, 2005 | 07:07 AM
mason's Avatar
mason
The '95 through '97 use the neon light bar for the third brake light. The ballast for the light usually goes out before the light bar does. Easy fix, it's located in the top of the hatch behind the interior panel. Unfortunately, the ballast and neon light bar are not cheap.
Mason
Hadden117
Dec 23, 2014 02:52 PM
JS-SD
May 9, 2008 05:01 PM
headshrink
Jul 9, 2007 01:34 PM
PHXKELLER
May 3, 2006 10:46 PM
