Jumpy speedometer
Old Jun 26, 2002 | 02:07 PM
ackusackus's Avatar
ackusackus
Jumpy speedometer
I can come up with the most messed up questions and you guys always have the answer.....
try this one....under about 40 mph, my speedometer oscillates +/- 10 mph. Once I get above 40, it steadies out.
1. Why does it do this?
2. How do I make it STOP?!?!?!?.....I can see it out of my peripheral vision and it really bugs me.
thanks,
Wayne
Old Jun 26, 2002 | 02:20 PM
odie780's Avatar
odie780
Jumpy speedometer
Your spedo cable needs to be lubed. Pull the cable and clean it up well and coat it with some white litheum graes and it will be fixed.
Old Jun 26, 2002 | 02:34 PM
ackusackus's Avatar
ackusackus
Jumpy speedometer
by "pull the cable", do you mean disconnect it from the instrument cluster, and shoot it down in the cable? Or pull as in pull the cable its self out (the inside part) of its housing and lube it?
Old Jun 26, 2002 | 02:48 PM
odie780's Avatar
odie780
Jumpy speedometer
I would pull the cable out if it was me, however you may be able to get away with spraying it while the cable is still in the housing.
Old Jun 26, 2002 | 02:57 PM
73Custom's Avatar
73Custom
Jumpy speedometer
This happened to my '73 F100 a few months ago. I pulled the cable to lube it, but I couldn't get it back in correctly. I assumed the outer cable sleeve was too worn from 28+ years of spinning. So I got a new cable assembly from NAPA for about $20 - works great now.
Just a thought.
Marty
Old Jun 26, 2002 | 11:44 PM
trixie's Avatar
trixie
Jumpy speedometer
If speedo cable stuff doesn't work, you probably are missing a tooth on your speedo drive gear in your transmission (or t-case). A tranny shop can probably hook you up with a new one, or you can just live with it like me
Old Jun 27, 2002 | 12:12 AM
holyjohnson's Avatar
holyjohnson
Jumpy speedometer
rylowe
Feb 28, 2015 04:45 PM
dfarland
Sep 23, 2010 03:06 PM
wibber
Nov 14, 2009 05:55 PM
hittman1422
Apr 3, 2009 05:34 PM
Rambo76
15
Mar 17, 2008 07:27 PM
