Studdering problem
Old Oct 15, 2005 | 05:01 PM
  #31
Popa Tim's Avatar
Popa Tim
I take that back... sorry I had missed the post where you said you had a manual tranny. Yes thats what its called but its for automatics, you can buy additivie or tranny fluid that already has it in.
Old Oct 28, 2005 | 02:35 AM
  #32
attroll's Avatar
attroll
I haven't done much more for this problem yet at this time. I have been just dealing with it for now.
I have noticed one thing more that I did not notice before. This problem only seems to ocure after the engine has warmed up. When I take off and the engine is not up to operating temp yet It seems that I can not notice this studdering problem. I am not saying it is not there. What I am saying is that it is not as prominent. I don't seem to even notice it.
Old Oct 29, 2005 | 03:37 PM
  #33
steamplant's Avatar
steamplant
Same Problem 1995 F-140 302
I have the same problem been kicking my a for over a year I'm gonna try the IAC tonight, let us know if the problem stays gone
Old Oct 29, 2005 | 04:29 PM
  #34
attroll's Avatar
attroll
Will do. But if you IAC fixes your problem please let me know that too.
Old Jan 1, 2006 | 01:55 PM
  #35
stevcher's Avatar
stevcher
I had a problem something like yours a few years ago with my 1992 5.8 53,000
mile when I got it and the guy before me never drove it in winter.I had shop look at it and they said the thermostat in the vechile was the wrong temp for what the computer setup called for they changed to right one and problem disappeared and I
have never had it happen again have 112,000 miles now and run real strong
Old Jan 1, 2006 | 04:02 PM
  #36
attroll's Avatar
attroll
I have had no luck with this since I last posted. Here is what I have done and what I am about to do.
I have changed the TPS and the thermostat with not luck at all. But I also noticed that I have white smoke coming out my exhaust and it is not oil. I am going through about 1/2 gallon of anti freeze every two weeks. So I am going to pull the head off this week and hopefully it is only the head gasket and not the head.
Once this is fixed I am praying that my studdering problem will go away.
Old Jan 1, 2006 | 04:13 PM
  #37
stevcher's Avatar
stevcher
antifreeze
sound like cracked head good luck
Old Jan 1, 2006 | 10:14 PM
  #38
lv2race's Avatar
lv2race
I just replaced my transmission modulator today because I was pumping out white smoke. I was about to pull the head and replace the head gasket, but thanks to this site, I replaced the modulator and fixed the problem. I replaced it about 2 months ago but must have had a bad unit. Run your engine for a minute and check the vacuum line coming from the modulator and disconnect at the intake manifold. If you see oil in the line, change the modulator, about $20. Be careful not to lose the pin in the modulator. Before you buy any more parts, I suggest you buy your own code reader. I nickled and dimed myself to death until I got a code reader. Best tool I ever bought. Takes most of the guessing away. You can also clear old codes and start fresh, and that can narrow down any new problems.
Old Jan 3, 2006 | 08:00 AM
  #39
junkmobile's Avatar
junkmobile
Originally Posted by Iron Horseman
Just got my 95 F-150 fixed from this. Check out the "Hesitation" thread in this forum.It covers it all. But most likely is the IAC. Simple 10 minute fix.
If have the same problem with my 94 150 i6 5spd. How do I get to this "hesitation" thread. I did a search but cam up with 100's of threads.
Thanks.
Old Jan 4, 2006 | 08:13 AM
  #40
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome junkmobile, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 4, 2006 | 10:06 AM
  #41
mechanicor's Avatar
mechanicor
Similar problem with my truck
I also have this problem, i have had it for the better part of a year, and havent been able to figure it out. I've got a '94 f-150 with the 4.9, and the 5 speed tranny. It's got 85k miles on it and no other problems. To be specific this problem only happens when accelerate real hard, and it happens in each sucessive gear at more or less the same rpm band. cant be sure what rpm, cause i dont have a tach, but it happens just after i shift on the lower end, sort of bucks like i'm running out of gas, then i ease up on the throttle, and it gets past it, so i hit the gas hard again and it roars up towards the top rpm range and then gives another shudder right before i should shift. Again this only happens when i'm really laying in the throttle, i.e. highway on-ramps, ofrpassing other vehicles, For some reason the truck does not get enough fuel in those places but otherwise works fine, it sounds like alot of people are experiencing this or something similar to it in more or less the same vehicle. for the life of me i just cant figure it out.
Old Jan 4, 2006 | 10:15 AM
  #42
johnsonswamp's Avatar
johnsonswamp
Sounds to me like your hitting the rev limiter.
Old Jan 4, 2006 | 10:49 AM
  #43
mechanicor's Avatar
mechanicor
I dont think my problem is a rev limiter cause once i get past hiccups i can get more rpm's out of it but i just drove it to work, and noticed like attroll said that the problem is not noticable when the engine is cold. A Clue?
Old Jan 15, 2006 | 01:55 AM
  #44
attroll's Avatar
attroll
It can not be the modulator in my case I have a manual trasmission. I also knew it was a cracked head or head gasket because I was losing antifreeze and getting bubbles in my radiator. I am putting a bran new head on it this week and hoping at the same time it fixes my studdering problem. It should be complete by this weekend. It has to be complete by this weekend because I am going snowmobiling and I need the truck to haul my sleds. I will keep everyone posted on what happens.
Old Jan 15, 2006 | 09:01 AM
  #45
lv2race's Avatar
lv2race
Snowmobile? I'm in Southern California and the only thing I have been wearing lately is shorts and a t-shirt. But I think it got down to 50 last night. The ocean water is still 58 degrees.
