I have not been able to locate the vacuum hose for the heater valve under the hood.
I will be doing a stereo upgrade this weekend so I will look under the dash for it.
If anyone knows where it is supposed to come through the firewall , let me know Please
I could be wrong here but I believe it's molded into one of the fat grommets in the firewall too so it shouldn't be that hard to spot, unless someone cut it off or tore it off right at the grommet.
On my 74 with A/C it crosses the engine compartment at the top of the firewall and goes into the cab on the drivers side just under the cowl lip. ON the inside it should go to the A/C control panel.
