ok i went to trade in my old ford yes trade in!! anyway i was going down the road and my blinkers stoped working so i checked the flasers and they worked then i got home and they stoped working and then after that my brake light stoped lighting up it is makeing me very very VERY mad !!i have running light but no brake light anyhelp whould be great ANY AT ALL thanks
Take all the bulbs out and clean the socket and the outside of the bulb for corrosion. While your at it, get a test light and see if you have voltage when somebody steps on the brake pedal.
I know what happened. Yep, fer sure. Your old truck realized you had decided to end the relationship, and took it out on you, that's what!
Seriously, check your multi wire connectors under the dash and behind the gauges. It sounds like something worked loose. Be sure to check for loose grounds as well.
Well with that kind of a gremlin on that "old Truck" I will give you $50 Canadian dollars.....cash max LOLOLOLOL
It could be the steering column connector has come loose, as previously stated, or it could be a dead/dying turn signal switch. All those non-functioning circuits run thru it.
Sparky
ps
$50 Cdn dollars Cash You deliver
think about it
