Setting idle speed '91 3.0
Old Sep 30, 2005 | 03:40 PM
mxhowes1's Avatar
mxhowes1
I know that the idle screw is factory set but some bozo before me cranked up the screw because the IAC (air bypass valve) wasn't working correctly. I would like to know the procedure to set the throttle plate screw correctly, can't seem to find the info anywhere.
I also need to know the desired idle speed, it doesn't say anything about it on my engine compartment sticker.
Thanks, Jim
Old Sep 30, 2005 | 11:02 PM
TallPaul's Avatar
TallPaul
I don't know about a throttle plate screw, but I have adjusted the screw on the throttle linkage to adjust the idle on my wife's '92 Aerostar 3.0. I think I have it set around 700 rpm. IIRC it seems when the air conditioner comes on it automatically adjusts the idle to stay where it is set.
Old Oct 1, 2005 | 10:27 PM
TallPaul's Avatar
TallPaul
Ok, was out in the Aerostar today. Here is what I observed:
Idle was 750 with air on and in gear.
Idle was 850 with air on and in neutral.
Idle was 850 in gear and air off.
Idle was 1050 in neutral with air off.
Anyway, set the idle so it is aroun 700 with the air on in gear and you should be fine.
Old Dec 25, 2005 | 02:57 AM
bumpin_BII's Avatar
bumpin_BII
you want to unhook the idle air bypass valve then crank her up and with it under no load back the screw out slowly untill it stumbles down and dies. hook the idle air bypass valve back up clear the ece and your idle will be ecu controlled. that is the way it is set from the factory and anytime something cause it to be messed with like bozo lol. either way that is the way that a dealership would set it. if it won't idle that way or dies even after the relearn then you have a problem elsewhere.
Prototypemech
Dec 13, 2013 09:10 AM
1982fordf100
Sep 5, 2006 09:20 PM
sdnorden
Jan 19, 2004 07:23 PM
wiggles
1997 - 2003 F150
Oct 28, 2003 02:22 PM
AWGuinn
Sep 2, 2001 08:59 PM
