Delaying rust while fabricating.
Old Sep 30, 2005 | 11:32 AM
ICEMAN36's Avatar
ICEMAN36
I sand blasted a 1936 Ford frame to clean and prepared for welding. Then got side tracked by life’s little problems. The frame is inside and covered but is starting to get a little surface rust. I have welding and fabricating to do and don’t want any thing on the frame that would be hard to get off, cause problems with welding or cause dangerous gas when welding. Is there a primer or treatment that would buy me some time? Or would a good standard primer of some sort delay major rust a while?
Mike
Old Sep 30, 2005 | 12:25 PM
uk1050's Avatar
uk1050
no expert
but ive always seen people sandblast then seal it with a good sealer.
RocketScience's Avatar
RocketScience
There are weldable primers available that may suit your needs. You can sometimes find them at your local Industrial paint supply houses, or if not, on the web.
Here is the product from Farwest Paint that we use:
X-6316 Weldable Primer
Old Sep 30, 2005 | 02:21 PM
frederic's Avatar
frederic
Being lazy, I just use regular primer with the expectation to sand around areas to be welded as necessary, and to sandblast the thing as a whole once the entire structure is complete (or chemical stripped, that works fine too).
You can buy weldable primer as suggested, but finding it at your local home center is not doable, and it's more expensive. Since I recycle sand, I just deal with having to blast it again once everything is welded together properly.
A friend of mine thought he was clever in spraying his metal work project with oil, and it did prevent rust. But getting the oil off at the end of the project to paint it was a real pain in the ****...
Old Sep 30, 2005 | 04:03 PM
Huntsman's Avatar
Huntsman
I would treat the surface rust with Oshpo? or some other acid based metal treatment, then prime with an etch primer. If it is damp in the garage, I would use an epoxy primer.
Old Oct 3, 2005 | 10:04 AM
ICEMAN36's Avatar
ICEMAN36
Thanks To all:
After researching your responses I ‘m going to try the product called Picklex-20.
Iceman
AXracer
109
Aug 21, 2020 02:41 PM
avf100
Sep 4, 2016 01:45 PM
AXracer
Dec 2, 2014 11:43 AM
lowtrkn2k
Oct 12, 2013 07:31 PM
Sharky146
Oct 1, 2010 09:26 AM
