Well while digging through my Ford CD I found this schematic for you of with all the parts on the rear liftgate with the corresponding part numbers and some instructions. Whip it out at the Ford dealership and raise an eyebrow .
Plus you can find the specific part thats broken on the schematic and maybe save yourself some cash.
Also the rivets do have a part number see 3 on the schematic which is part number 390134-S100.
To remove the latch:
1. Open liftgate and remove liftgate door trim panel and liftgate handle, if so equipped.
2. Disconnect liftgate latch release rod from control assembly.
3. Remove three latch retaining screws and remove luggage compartment door lock mechanism cover (43243) and latch from liftgate.
4. On vehicles equipped with liftgate ajar warning switch, pull latch slightly away from liftgate and disconnect electrical wire harness from the latch.
To install, reverse Steps 1 through 4. Tighten latch retaining screws to 4-8 N-m (36-70 lb-in).
Rear Liftgate Parts Breakdown
Somebody actually posted that site here on the Aerostar forum a few months ago. I'm just repeating his post. I bought mine on Ebay just like you, Krankshaft The guy probably downloaded that same CD off of the site and sold it to us poor unsuspecting souls
