What can I do to reduce my hydrocarbons? Wont pass :(
The probable causes of high hydrocarbon (HC) in your vehicle are listed as follows:
Electrical Misfire
Too Much spark advance (or initial timing)
Air-fuel mixture too lean
Vacuum leak
Leaking exhaust gas recirculation (EGR) valve
Malfunctioning closed-loop fuel metering system
Engine wear
Electrical Misfire
Vacuum leak
Engine wear
Originally Posted by Tectron1
Cool Thanks,
I changed the oil and airfilter tonight and dumped in several bottles of gas line antifreeze. I checked not to long ago for vacume leaks. I hope this will bring it down.
Steve
Steve
1) change air filter
2) run tank down to ¼ or less & add 2 btls. "Heet"
3) run the vehicle for at least 40 min. before taking it for testing. (if I had to wait long to test I'd make sure I kept it idling and the cat. hot).
Once you pass.. go top off the tank.
Wish you the best.
Respectfully,
Automatic
AZ_Tuc250
11-27-2014 08:11 PM
gobblerman
96
07-31-2010 01:05 PM
mremail1964
05-31-2006 10:03 PM
Gooney
1983 - 2012 Ranger & B-Series
17
05-02-2005 07:43 AM
