looking 4 headers
Old Sep 28, 2005 | 10:13 PM
fast67's Avatar
fast67
looking 4 headers
i need headers 4 my 67 f100 with a 460 will headers of 74-79 fit?
Old Sep 29, 2005 | 05:38 AM
jowilker's Avatar
jowilker
fast67 Welcome to FTE The best truck show on the net.
You will have to look to the late 70s year models for your headers. The 460 was not offered in 67 for the pickup, so you will not find any available for that year.
John
Old Sep 29, 2005 | 08:16 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Go to the Bronco Grave yard site..one of the FTE sponsor's..should be in the Sponsor columm on the left side of the page...
Look under Trucks.. and go to 460 swaps...Headers P/N 20960 fit 67-79 2 wheel drive trucks with the 460...there made by L&L....and there $425
Good Luck,
Russ
Old Sep 29, 2005 | 09:49 PM
fast67's Avatar
fast67
i was wondering if the 1 from 74-79 f100 would fit because they came with 460!
Will the headers give me more power like they say they do ? I have 460 block of 95 pick up heads of a 74 lincoln eldelbrock intake and carb and rv cam but it dosent idle rough u cant even tell ! c6 trany b&m sifth improver stock 9 in rearend sithing on 22"
will heders make it fill stronger?
Old Sep 30, 2005 | 12:55 AM
thesprocket26's Avatar
thesprocket26
The headers will fit. Check in my "Red Ranger" gallery. Headers don't give you more power. They allow your motor to be less restricted. Mine are made out of metal so they feel pretty strong.
Old Sep 30, 2005 | 06:19 AM
390fe's Avatar
390fe
The trade-off between any power gained versus dealing with tight-fitting, hard-to-install, potentially leaky headers that cause high underhood temps should weigh heavily on your decision.
I had a set of headers on a pickup, and I regret every minute of it. They belong on race cars, not daily drivers, in my opinion. I spend zero time maintaining my cast iron manifolds, and they don't leak. Ever.
'Nuff said.
Old Sep 30, 2005 | 09:03 PM
baitmaster's Avatar
baitmaster
no probs
My Hookers have been on my '72 for almost 9 yrs now. They are installed on the newly rebuilt 390. Never have had to do anything with them, except for re-install. I think the secret of a good install is premium gaskets, torque the bolts in the right way, and some juice on the bolts if you ever have to remove them. Wish i could find a coated set. One thing I did notice when i installed these with a K&N filter, was that I could pull my boat up the hill in 4th, before I had to downshift.
Old Oct 1, 2005 | 04:33 PM
Ford_Six's Avatar
Ford_Six
I always use dead-soft copper or aluminum gaskets, and have never had a problem. I would look for headers that have ball flanges on them, they seal much better than the flat gasketed flange, plus they flex. If you want to keep underhood temps down, paint the headers with the 1200* paint they sell at schucks. Spray about half a can down each runner, and paint the outside too. On stainless headers, just do the inside and they won't turn blue.
Old Oct 2, 2005 | 04:35 PM
TK70Ranger's Avatar
TK70Ranger
'Nuff said.
Manifolds on an FE that DON'T leak? How'd you manage that? The headers that were on my truck never leaked, made it a pain to get at the starter, but they never leaked, previous owner (my dad) took them off because the noise in the cab bothered him (I think ditching the flow master would help more, it sounds like crap) You can wrap the headers to get rid of the underhood temps, if that bother's you.
Old Oct 2, 2005 | 06:16 PM
ajoelane's Avatar
ajoelane
Wrap headers?
I just purchased a small block ford engine and it has headers, they appear to be chrome? I never thought about under the hood temps till i read these posts, what kind of wrap are you speaking of? Is the under the hood temp a problem with my 1968 f-100, it seems to have enough grill to allow air flow.
Old Oct 2, 2005 | 07:36 PM
TK70Ranger's Avatar
TK70Ranger
Your header's are probably ceramic coated. Its called exhaust wrap or exhaust tape, Summit or Jegs probably has it, my dad uses it on his big rigs to keep temps down (big turbo and pipes under hood)
Old Oct 3, 2005 | 06:49 AM
ajoelane's Avatar
ajoelane
Thanks Tk70 Ranger. I appreciate the reply
itsabullitt
Jun 20, 2013 06:57 PM
CHAD250CC4X4
Aug 21, 2009 11:18 AM
67owner
Jan 29, 2007 03:29 AM
Busted knuckles
Apr 10, 2004 07:58 PM
Busted knuckles
Exhaust Systems
Mar 28, 2004 08:23 PM
