I have a water pump question running here allready but I need some help from anyone who drives a 97 psd and has a aux gauge that shows acual temps, not a range of temperature like the stock gauges show. If any one can take a reading of what your truck runs for temp at highway speeds with no load or trailers and at idle, just post those temps here. I can then have my truck checked at the same intervals with a aux gauge or at the mechanics shop. Ever since I had a water pump changed, my truck runs a lot hotter. I am trying to trouble shoot away possible problems with the sending unit, factory gauge or if the re-man pump is no good. I figure there are enough guys on this site still with 97 psd's and I just may be able to get a coolant temp reading from a simular truck to compare to what my truck is doing. If my temps are close then I will belive the sending unit or gauge went on the fritz. I just dont want to belive the parts store guy when he says its the gauge, drive your truck. I dont think they will pay for a engine if it turns out to be their pump. My factory gauge worked like it allways did the day before I replaced the pump and the day after they changed the pump it runs a whole lot hotter on the same gauge. Thanks for any replies and temps ahead of time.
Ed
cannot give you more than what most fords read on stock gauge... between the N and the O .. is all i ever see. these trucks do not run hot and alot of guys for some reson tow w/ out a mechanical fan and it still runs in the normal range.. most engines will run 180-210*F. checked your thermostat??? did you use ford gold coolant??
i would have it checked out on a scanner so that you can see what the ECT reads to the pcm and gauge... unless you want to just replace the cheap $30 sendor.
