Last week I was driving in wet weather and my engine was stalling especially when drivng through moderate puddles. I did get a code for my CPS, but sence I replaced the device it has stoped raining. I have a MAC air cleaner with the K&N outerwear and I am hoping the water is not coming throught the old air cleaner hole and causing problems at near related electrical components. If any have some suggestions it would surely be appreciated.
____________________________________________
99 F350 PSD Extended Cab 4X4. Edge, MBRP
My '01 had CPS problems only when it rained. Eventually it started having issues when dry also. I replaced the CPS and continued having the same problems so I cleaned the electrical plug and the contacts on the CPS and still had problems. After that, I replaced the CPS again. Problem solved.
I guess some of the CPS's were bad from the get go. I would clean the connections good with contact cleaner or alcohol and see if it helps. You might have gotten a bad new CPS also.
Thanks AustinS, I cleaned the contacts with a good contact cleaner and also applied dielectric compound on the O-ring and fitting to hopefully eleminate any moisture in the future. I will only know if it rains. I do live in the High Desert of California and rain is rare, but when it does, it usually all comes at once. I just hope when Dunebuggy season starts my adventures will be without problems.
