Removal Selector switch for vent/Ac etc... etc..
Old Sep 27, 2005 | 10:29 PM
Jack01's Avatar
Jack01
Does any one know how to remove the Selector switch from a 95 F150 I have a vacuum leak at the switch and I need to remove it my Chiltons book does not cover the 95 it shows how to on 87 thru 91 models but my dash is slightly diff than those model years....
Old Oct 30, 2005 | 05:14 PM
Jammyster's Avatar
Jammyster
Jack01,
I have a 1992 and I think the dash is closed to the same. I also had to replace mine. The trim piece above the switch panel below the radio is just held in with clips. I carefully pulled it off and it exposed two screws on the top of the panel cover that is around the switch plate. I removed the two screws for the cover panel to find the two screws that hold the plate in that has the fan speed switch and the mode switch. I remove the two screws that hold the plate in and pulled it out. The switch on the right has one wire connector and one vacuum connector with one nut holding the vacuum connector to the switch. I disconnected the wire connector, took the nut off the vacuum connector and there was one screw that holds in switch to the plate. Reversed the procedure the replace everything. Hope that helps.
Old Oct 31, 2005 | 07:56 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Jammyster,to Ford Truck Enthusiasts!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Docbandy
Feb 17, 2017 01:54 PM
Erictusio
Feb 13, 2017 12:58 AM
Xamdrob
2009 - 2014 F150
Jan 20, 2017 12:35 PM
texasblue55
Jan 29, 2016 02:08 PM
jgilrfr
Jul 31, 2013 03:46 PM
