1966 - 1977 Early Broncos
carb size
Old Oct 4, 2005 | 11:56 AM
HMA-169's Avatar
HMA-169
carb size
Have a friend that just bought a '69 Bronco 302 with a two barrel. He now has a 302 4 barrel Ford intake but wasn't sure of the type or size carb was used. Anybody know what the OEM setup was or what he should consider choosing. He will be keeping the engine stock.
cds
Old Oct 4, 2005 | 10:53 PM
Boba Fett's Avatar
Boba Fett
The oem carb is some variant of an Autolite 4100. I'd keep the 2-barrel. Offroad you won't run the rpm to benefit from the 4. When you're wheeling and stuck and you punch the throttle and open the secondaries, that's when you loose control, bounce off an obstacle and fall on your side, and somebody tells you fuel injection is better for wheeling.
Old Oct 4, 2005 | 10:57 PM
fordborn's Avatar
fordborn
Welcome to Ford Truck Enthusiasts. In order to make it easier to navigate please read the following: Forum Guidelines
In Addition to the Tech Forums there are State/Province Chapters that bring local members together for meets, events and just plain fun.
Once again...Welcome to the FTE Family
