AC evaporator
Old Jul 10, 2002 | 03:08 PM
vettman's Avatar
vettman
Post AC evaporator
I've searched hi and lo here in Northern VA for an AC evaporator for my 1976 F350, 2 wheel drive with 460. I've spoken to contacts at LMC, and Obsolete Ford parts--neither had the item. Ford dealers in this area don't have a listing. Could not find one on EBay. I believe this evaporator was used up to 79. Any help/suggestions would be appreciated.
Old Jul 10, 2002 | 03:43 PM
KJKozak2's Avatar
KJKozak2
AC evaporator
Pardon my ignorance, but do you mean the compressor? If not, what does an evaporator look like?
I got a 74 460/c6 and was gonna rebuild it until I found the block was trash. Aside from the block, crank, pistons, & cam, I have everything else off of it in boxes. It had AC and I know I have the compressor.
If I know exactly what you're looking for I can see if I have one.
E-mail me directly at: kevin@brayarch.com
K.
Old Jul 10, 2002 | 04:17 PM
dfisher1's Avatar
dfisher1
AC evaporator
Vett,
These parts are not that vintage. You should be able to call Pep Boys or some other local yocal and find an evaporator. I'll call around down here in florida and see what I can find.
Secondly,not to vettster but to the previous post, the evaporator is the coil inside your truck. It's the thing that get's cold when the A/C is on.
My Way is the Highway,
KingFisher
Old Jul 10, 2002 | 04:33 PM
Franklin2's Avatar
Franklin2
AC evaporator
Go here
http://www.car-part.com
and enter your info. I just did and got lots of hits from $100-down. I put in F350 but it listed other models too, so they all must be the same.
Old Jul 10, 2002 | 09:51 PM
vettman's Avatar
vettman
AC evaporator
[updated:LAST EDITED ON 10-Jul-02 AT 10:52 PM (EST)]Really don't want to go with used evaporator; assuming I could find 79 vintage, 23 years is getting near upper limit for an evaporator. Given expense of installing and recharging (1 lb. cans of R12 are going for $60 in Northern VA), I would like to avoid going "used" on the evap. I spent $180 this morning for 2 cans of R12 and dye test just to locate the leak. If I can find a new evaporator, I think I'm going to replace everything but the condenser, and convert to R134. I found a local outfit that will make up new lines. If I go this route, I'll do the remove and replace, then take it to the shop for vacuum draw down/leak check, and recharge.
Old Jul 10, 2002 | 11:29 PM
ranger_4x's Avatar
ranger_4x
AC evaporator
paul somlo
Escape & Escape Hybrid
Aug 4, 2015 12:59 PM
Calcifer
Maryland Chapter
Mar 17, 2015 08:51 PM
capt caper
Sep 30, 2014 11:46 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jun 21, 2014 07:18 AM
rutang
Aug 8, 2005 08:25 AM
