1997 F450 Help
Old Sep 29, 2005 | 09:44 PM
ceopi's Avatar
ceopi
The truck was not running when I bought it...The starter was hanging by one bolt. So I guess i gort lucky so far because i pretty much stole the truck because eevryone thought the engine was bad...The check engine light has not come on except when i unplugged the ips. But I reset the computer and put a new icp on it and now it is out. The scanner was onre of thoses 80.00 autozone scanner which I took back today..I have a guy that works on all of the ups trucks coming to look at it this weekend..The only thing a have notice today is that the IPR had a lot of play in the plug..I will let yall know what the UPS guy says..Thanks for the help...
Old Oct 6, 2005 | 12:57 PM
ceopi's Avatar
ceopi
I just had a guy look at it and he said that none of the left hand side injectors are firing..He said it might be the wiring harness or bad injectors..
Old Oct 6, 2005 | 08:08 PM
ltfox's Avatar
ltfox
Most likely a burnt valve cover harness or connector.
Old Oct 6, 2005 | 08:22 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yeah....it's pretty unlikely that all the injectors on one side failed simultaneously. It just about has to be in the harness/connector.
rob40cal
Feb 11, 2013 08:20 PM
Txfodiesel
Nov 28, 2012 10:30 PM
rigrunner
Sep 15, 2012 02:02 PM
NauticaEE
Sep 30, 2011 01:06 AM
edub32
25
Feb 20, 2009 05:51 PM
