1997 F450 Help
Old Sep 26, 2005 | 07:13 PM
ceopi's Avatar
ceopi
Cool 1997 F450 Help
I just got it running but it will on rev to about 2500 RPMS...I drove it around the block and it would barley go even with the pedal to the floor...I have replace fuel filter,CPS,Barreries, and I have about 50 psi of fuel pressure...Do you think it is the ICP...I tried unplugging the ICP and it ran a little rough and the check engine light came on so I reset the computer and check engine light is off now...Thanks
Old Sep 26, 2005 | 09:07 PM
ltfox's Avatar
ltfox
Did you try driving it with the icp unplugged.??? Just ignore the cel.
Old Sep 26, 2005 | 09:08 PM
ltfox's Avatar
ltfox
50 psi is normal.
Old Sep 26, 2005 | 09:19 PM
ceopi's Avatar
ceopi
I tried reving it up and about 2000 to 2500 rpms at the most...
Old Sep 26, 2005 | 09:30 PM
ceopi's Avatar
ceopi
Where is the best place to get the ICP....Or is it a dealer only part..
Old Sep 26, 2005 | 09:49 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Maybe e-bay....I don't think the parts chains carry it.
Old Sep 26, 2005 | 10:36 PM
ceopi's Avatar
ceopi
Thanks for your help
Old Sep 28, 2005 | 09:38 PM
ceopi's Avatar
ceopi
Will not rev over 2200 rpms...I bought a scanner and it is not giving any codes at all...What next...I think I am going to give up and put the truck on ebay for sale and go buy a new truck..
Old Sep 29, 2005 | 08:12 AM
1997F-350's Avatar
1997F-350
not all scanners work on our trucks. some auto parts stores use cheapies and some use quality. if you can drive your truck to one they will let you use it free.
Old Sep 29, 2005 | 06:50 PM
cookie88's Avatar
cookie88
FTE Emeritus
What happened witht he ICP and/or fuel pump? Change your mind or that didn't fix it?
Old Sep 29, 2005 | 07:30 PM
Kwikkordead's Avatar
Kwikkordead
Hmmmm, low HPOP pressure? Failed IPR?
Old Sep 29, 2005 | 07:31 PM
ceopi's Avatar
ceopi
Fuel is 50 psi running...I just put the new ICP on it but no change.. it still only revs to 2200 rpms...and tries to die when I put it into drive..I put the old cps back on it but still no change....New oil,filters,cps,icp,batteries...I even washed the stupid thing..I give up...What next glow plugs and injector o rings maybe..or oil pressare switch...Please help...
Old Sep 29, 2005 | 09:04 PM
cookie88's Avatar
cookie88
FTE Emeritus
What kind of scanner did you buy? Like 1997F-350 noted earlier...not that many of them work on the diesels.
Has the check engine light come back on since your've started working on it?
Old Sep 29, 2005 | 09:09 PM
ltfox's Avatar
ltfox
Have you check the valve cover harnesses??? Look for burnt pins or melted wires.
Like Kwik said maybe low HPOP preessure. Maybe the IPR or IPR oring's????
Old Sep 29, 2005 | 09:13 PM
1997F-350's Avatar
1997F-350
i wouldn't rev it up like this. its not a gasser. not like its gonna clear a fouled plug or anthing . i h8 gas.............it will let you know when it wants to go.
anyways please enlighten us on the past. what brought all this on. did you just buy it??? sitting for a while????
do you know anyone with a snap on scanner? i would be curious what your running pressures are and what a buzz test turns up. have you checked uvc harnesses? is your oil low/old?
try and find a 1 man show mech shop who can help you if hes got one. you know the kind of place that isn't busy as all hell. please keep us updated.
whats the fuel like in the filter bowl? was your water in fuel light ever on recently?
