They keep urethane adhesives like sikaflex in polyethylene bottles and containers because it does not adhere well to them. The only way to fix polyethylene is to fuse it with heat.
We 'welded' two, 0.5" thick pieces of polyethylene together with a chunk of the same - used as a welding rod, and a standard Bernzomatic propane torch. If that gives you any ideas.
Speaking of plastic repair, anyone know what kind of plastic they use for the hard interior trim?
I broke the retaining clip to the overhead sunglasses holder, and the dealership wanted to sell me the whole overhead unit. Electronics and all. I passed. I've also broken one of the studs that hold the A pillar trim on.
I've tried experimenting on the back side with PVC, CPVC, ABS, Epoxy, urethane, and super-glue. None of them adhere well, nor do they seem to melt the plastic like a solvent weld "glue" should.
There's a ton of this plastic trim in this big van of mine, and I'd sure like to know how to repair it.
Any thoughts here?
What's a plastic welder? How, and how well do they work?
