390 Industrial
Old Sep 23, 2005 | 05:06 PM
mswift's Avatar
mswift
390 Industrial
I found this ad in the local nickel. i was thinking about checking it out.....
WOOD HAULER 1972 Ford F-600 20' Flatbed, 390 Industrial V8, 5 and 2 speed, 10.00X20 tires, $1250
Old Sep 23, 2005 | 05:13 PM
ford390gashog's Avatar
ford390gashog
go for it. it will be a 391 or 361 or 330 . most had the 361 not the 391 enignes. people call them 390 engines when it is time to sell.
Old Sep 23, 2005 | 05:19 PM
mswift's Avatar
mswift
As I am not familiar with the FT, is there any physical characteristics that stand out between the 361 and 391? Or do they look same as 360/390/352, do to eachother?
Also, I am getting close to rebuilding a 390 for 'ol blue, Would any valuable parts to on this 361/391 to use on my build?
Mike
Old Sep 23, 2005 | 05:24 PM
ford390gashog
they look the same for the most part. ft enignes have a cast iron timing cover and a steel crank and are externally balanced. super low compression.
Old Sep 23, 2005 | 07:00 PM
rusty70f100's Avatar
rusty70f100
I agree, go for it!
There's plenty of good parts to use on that thing. The oil pan is bigger than the standard FE pan, by quite a bit. As was mentioned, is the forged steel crank, which can be converted to internal balance by a machine shop. The block is stronger than a standard FE block, but also a little heavier. You'll also have to get the crank snout machined down since it's bigger than the standard FE crank. Either that, or use the FT timing cover and pulley's.
So I say, use the block, oil pan, and possibly the crank. Using the crank will add cost to the rebuild, but it is a VERY strong crankshaft. If you're thinking of using insane amounts of nitrous or boost, the FT block and crank will take it. Otherwise, the standard FE crank will work just fine.
If the guy says it's a 390 then it most likely is an FT 391. If in doubt, measure the stroke before you buy.
scott78f2504x4
Ford Truck Parts for Sale
54
Aug 25, 2014 06:26 PM
AJUSAcom
Vendor Specials, Discounts, Product Announcements & Group Buys
Jan 11, 2012 07:40 PM
Hypoid
18
May 5, 2009 10:13 PM
whitezombie70f-100
Feb 10, 2008 11:42 AM
GeneStoner
Apr 25, 2003 01:51 AM
