Engine-driven welder
Old Sep 23, 2005 | 09:22 AM
mikebon08's Avatar
mikebon08
Do any of you guys know if there's someplace around Wichita or KC that sells used equipment, like an engine-driven welder/generator mounted on a trailer? Brother, brother-in-law, and I have some projects to work on.
Old Sep 23, 2005 | 06:49 PM
Thomasm67's Avatar
Thomasm67
Look for miller welder's
Old Sep 23, 2005 | 09:36 PM
fordnut1985's Avatar
fordnut1985
Call the local welding shops and check the clasifides and auction anouncements. Theya are always in there. I have been kicking around getting one for the shop but just can't justify it yet.
Old Sep 23, 2005 | 10:43 PM
Thomasm67's Avatar
Thomasm67
On Rides a couple wks ago Miller Welder had a New 1929 Ford Model A truck roaderst built for the 75th aniversary had a roush built 302 in tha put out over 450 ponies they also put together a welder to match the truck pulled the 20 horse motor out and set in it's place a 300 horse roush 302 and it worked.
Old Sep 24, 2005 | 08:12 PM
mikebon08's Avatar
mikebon08
Sounds pretty cool....I've got a 302 that's going to be loose in a bit. How the heck do you attach a 302 to a welder though?
Old Sep 24, 2005 | 08:17 PM
fordnut1985
if you can find a gas powered welder/gen with a bad engine it can't be too hard. The ones i have looked at use a rubber spider coupler to attach motor to gen. I might even have a coupler around the shop that would bolt up to a 302!!!
Old Sep 24, 2005 | 08:24 PM
mikebon08's Avatar
mikebon08
Here's an idea to bounce off you guys...how big a deal would it be to hook up an air compressor too? Make a trailer that has pretty much everything--welder, generator, compressor, toolboxes, etc.
Old Sep 24, 2005 | 08:30 PM
fordnut1985
Seems like it would be pretty easy with an A/C compressor, well switch, and a tank and you would be good to go!! BTW, if ya find a welder minus the motor I have a couple running VH4D Wis-Con (formerly Wisconsin engine) that you could have. If I dig hard enough I could even get you a govener, elec. ign., and a few other goodies so it will be perfect. That's the same engine they use on them anyway.
Old Sep 24, 2005 | 08:32 PM
mikebon08's Avatar
mikebon08
Actually I was thinking of finding a belt-driven compressor and mounting it alongside the engine....what CFM rating does an a/c compressor have?
Old Sep 24, 2005 | 08:35 PM
fordnut1985
Not sure but my dad and I made a simalar set-up on his old 74 cheby. We had a 15 or 20 gal tank in the bed and it kept up with me running my 3/4" impact on the loader tires. If your looking for an air compressor like what they use on big trucks to run air brakes you could be looking at some sserious coin!!
Old Sep 24, 2005 | 08:39 PM
mikebon08's Avatar
mikebon08
No, just thinking of the usual home or small shop compressor with belt drive. Just replace the 5 HP motor with a 302.
Old Sep 24, 2005 | 09:12 PM
husker's Avatar
husker
An old AC compressor is easy because there are usually engine mounts to put it on the front of the engine without building brackets if using a vehicle motor. Just add a manual switch to the clutch and you are good to go. I don't know what PSI they pump, but a pressure switch could also be wired in.
Old Sep 25, 2005 | 07:35 PM
fordboy_52's Avatar
fordboy_52
we have a 1959 lincoln and it works great, gets used alot and still runs like a champ
Matt
Old Sep 28, 2005 | 10:50 AM
fordnut1985
Husker, I used a well pump switch and had it set around 120psi, I'm sure there are better setups out there one could use but hey, it worked lol
Old Sep 28, 2005 | 07:36 PM
husker's Avatar
husker
I love redneck engineering.
