Baffled
Old Sep 23, 2005 | 02:23 AM
Roaches's Avatar
Roaches
Baffled
I'm having a strange problem with my Ranger...there's a rattle when I step on the gas, it's much worse when the humidity is low, when it rains though, it runs normally. I wondering if it could be a gasket that has been exposed to the weather, something that was lubricated & sealed? Wild guess on my part...
It's a 1999 4 x 4
With a
3.0 L FFV V6 engine
regular cab
Old Sep 23, 2005 | 08:51 AM
D-ranged2.5's Avatar
D-ranged2.5
Is your motor pinging? Have you changed your spark plugs or checked them out to see how they look lately? I have a slight rattle when I push in the pedal sometimes, but it's not very loud. Is yours pretty loud?
Old Sep 23, 2005 | 09:17 AM
'04 4.0 XLT's Avatar
'04 4.0 XLT
Is it more of a flimsy type rattle or is it a knock?
When I hear rattle, I'm thinking exhaust, or more specifically the heat sheild on the catalytic converter. They can warp and become rusty.
Old Sep 23, 2005 | 05:26 PM
Roaches's Avatar
Roaches
It's a rattle....I'll take a look, I was afraid it might be the engine.
Thanx :-)
Old Sep 23, 2005 | 06:27 PM
Bob Ayers's Avatar
Bob Ayers
Try a tank of premium gas. If the rattle is less, or goes away, what you are hearing is pinging.
Old Sep 25, 2005 | 05:12 PM
Roaches's Avatar
Roaches
I checked the exhaust system, everything seems kosher...I'll try the premium gas, Bob (next payday LOL) I'll let you know if it changes anything.
Old Sep 25, 2005 | 05:14 PM
Roaches's Avatar
Roaches
I didn't think of that...I'll check that too. It's not very loud unless I'm really stepping on it, usually going uphill.
Old Sep 25, 2005 | 09:37 PM
=ender='s Avatar
=ender=
Roaches, I wonder if this is somehow related to my post as well: https://www.ford-trucks.com/forums/s...d.php?t=413951
I'm bringing mine in tomorrow morning to find out what could be up.
Old Sep 26, 2005 | 06:10 AM
D-ranged2.5
Be careful with using premium gas though... if you get some and it takes care of the rattle, great. You can assume the rattle isn't a big problem and go back to regular. But if your Ranger manual says to use 87, stick to 87 and ignore the rattle. Using higher-than-recommended octane can cause some pretty nasty build-up on your engine components over time. That, and it costs more without providing substantial benefit.
I changed my sparkplugs around 70K miles I think. Use something other than Bosch Platinum though. That's what I used and everyone I talked to about it said they're sub-par. Of course, this is AFTER I bought them, but hey... if it bothered me that much I'd replace them again, right?
Old Sep 26, 2005 | 09:33 PM
=ender='s Avatar
=ender=
Had a similar problem (see the link I put in my last post above) and the garage reprogrammed the PCM to the latest upgrade. No more rattle/pinging now and it was covered under the warranty so no charge either.
Old Sep 27, 2005 | 03:23 AM
Roaches's Avatar
Roaches
Oops
Yes, I read in the small manual that came with it that I should only use 87, so I guess I'll stick to it now(it's not payday so I haven't filled it up yet)...I'm kinda desperate for a solution.....It does have over 70,000 miles on it, I'll check the sparkplugs next....
Last edited by Roaches; Sep 27, 2005 at 03:39 AM. Reason: I screwed up the sentence
Old Sep 27, 2005 | 03:31 AM
Roaches's Avatar
Roaches
Hmmm
Thanks for the info - I'll try it if the sparkplugs don't prove to be the problem - (basically I'm going to go for the cheapest solution as I'm stingy) If I'm not being too inquisitive, How much did it cost for the upgrade?
Old Sep 27, 2005 | 06:48 PM
=ender='s Avatar
=ender=
Since my truck is still under warranty, it didn't cost me a thing. No clue what it might cost otherwise, but maybe call ahead and get some estimates around town?
