Front end ?????'s
Old Sep 26, 2005 | 08:28 PM
67f100's Avatar
67f100
Does anyone make a complete front end rebuild kit? If I am going to have it out and apart I might as well go through it get it back to "new". I checked pst and theres ran around 250. But I didnt think it came with everything. there were no king pins. Right now I think bushings will be all it needs.
Old Sep 26, 2005 | 10:31 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
67F100, go thru your local parts supply, Ford dealer, and LMC for everything you might need to replace before you tear down. Many people never replace the beam pivot which can be bad as well radius arm bushings also and look into replacing with polyurethane vs rubber bushings. New king pin bushings that are reamed not honed with the proper "king pin reamer", beams bent for proper camber then front alignment which you can do yourself. Use "heavy duty" shocks (I've the best luck with Monroe Mag 60's) as you have alot of iron in front. All steering joints and steering box tight, no slack or loose? Rewards when done right are great!
.....=o&o>.....
Old Sep 26, 2005 | 10:44 PM
4Cammer72's Avatar
4Cammer72
i used performancesuspensiondotcom and got the complete rebuild kit with graphite impregnated urethane bushings. i got everything with it except new spindles. very complete kit. 219 shipped to the door.
Old Sep 27, 2005 | 05:57 AM
jowilker's Avatar
jowilker
F100, There are no kits available AFAIK. Radius arm bushings, king pins, brake lines, rotors, pads, brake lines, master cylinders, boosters, are all available at most every parts house counter.
John
Old Sep 28, 2005 | 08:45 PM
67f100's Avatar
67f100
Will I have any problems putting the 67 front end under the 74? Its just so I can roll it around and put it on a trailer to haul it off when I am done with it.
Old Sep 29, 2005 | 06:06 AM
jowilker's Avatar
jowilker
As posted everything is bolt up exchange, so if the 74 fits the 67, the 67 will fit the 74. Or at least it will in therory, I have never hear of anyone doing it.
John
jp67stang
Jan 22, 2012 07:14 PM
67f100
Sep 20, 2005 08:11 PM
dave74-360bb
13
Sep 13, 2005 07:46 PM
mvee72
Dec 14, 2002 10:51 PM
Matt67
Aug 22, 2001 02:50 PM
