93 Ranger 4.0 pinging, bogging...
Old Sep 21, 2005 | 12:39 AM
arlandra's Avatar
arlandra
I have a 1990 ranger 2.9 and Ive cleaned everything, comlete tune up, distribitor
MAP cleaned and replaced, OS sencor and I still get a code 41 No exhaust gas Oxygen switching detected allways indicating lean?, no RPM control cannot control RPM low during self test or idle control inopertive. How do I get my power back, I can't get up the hill!
Old Sep 21, 2005 | 10:35 AM
mrshorty's Avatar
mrshorty
Is your 41 a KOER code, memory code, or both? The KOER RPM control code is often symptomatic rather than diagnostic. Are these the only codes that come up (other than 11's)? If you do get 11's, where are they coming up at (in other words, which tests are passing)? Have you thoroughly checked the O2 sensor signal wire between the sensor and the computer? Computer grounds intact (best checked electrically rather than visually)? What is your fuel pressure? Vacuum/Exhaust leaks?
iracekx
1983 - 2012 Ranger & B-Series
28
Nov 17, 2014 06:11 PM
itswrongway
Escape & Escape Hybrid
Oct 10, 2014 08:48 PM
charlieranger
Sep 3, 2010 07:37 AM
bgirard78
Nov 12, 2007 05:25 PM
mike_v2v98
Nov 27, 2002 12:38 AM
