Change steering box.
Old Mar 19, 2002 | 10:44 AM
Mil1ion's Avatar
Mil1ion
Old Jul 23, 2002 | 02:27 AM
GPW66's Avatar
GPW66
While working on my transmission I notice the seals are leaking on my steering box. I have a 78 250 with a 460 engine. I was wondering if the steering box from my 76 parts truck which is a half ton would bolt right on the 3/4 ton truck. It also looks like it would be quite a job to change. Is it easy or is there tricks to do that can make it easier.
Old Jul 23, 2002 | 05:10 AM
Amberlyns75's Avatar
Amberlyns75
ive changed mine a few times. Its not as bad as it looks. Its mainly diconnecting the steering pump hoses, pitman arm, three bolts that run through the frame into the gear box and 1 bolt on the steering shaft. Thats about it. I takes about one hour if the truck doesnt give you a hard time. My only problem is getting the darn steering box and pump to work with each other in a loving manner after getting it put back together. I thought it look like a painful job too, It really isnt.
Old Jul 24, 2002 | 12:10 AM
kris's Avatar
kris
i changed the steering box in my 3\4 ton 73 ford i put in the same one from another 3\4 ton and it took a couple of hours but i know putting one on from a smaller motor dosent take much longer good luck
Old Jul 24, 2002 | 11:57 AM
dfisher1's Avatar
dfisher1
GP,
Call a parts store and compare parts numbers. If they are the same your good to go. If there not, you'll have to lay them out on the ground and figure a way to make it work. My guess is the pitman arms are different. Be gentle while doing the swap.
KingFisher
Old Jul 25, 2002 | 08:27 AM
GPW66's Avatar
GPW66
Well you guys make me feel comfortable that I can do it. Just to find the time to do it. Have other things to fix first on the truck. Like keeping it running after 10 miles of driving.
I guess it won't be as difficult as it looks. I just will keep it topped up with fluid til I can make the change. Thanks agian guys and gals.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
