2000º+ Egt's!
Old Sep 18, 2005 | 09:08 PM
Hightempsilicone's Avatar
Hightempsilicone
Exclamation 2000º+ Egt's!
A buddy of mine was driving over a freeway overpass this afternoon and his Edge/Attitude EGT read 2000F +/-. He has a full 4" turboback exhaust and the edge as previously mentioned. I think he was on the lowest setting and not towing anything at all at the time.
Some history on the truck-
It has 220000+ miles and recently puked ATF towing 10-12K toybox up a long grade 3 months ago.
He installed an aftermarket transcooler with a temp actuated fan. The edge/Attitude and the exhaust at the same time. After the install a week later the oil seals blew (Not sure if it was the rear main??). Had the seals replaced and now this excessive EGT problem. The thrmocouple is installed preturbo on the manifold (Exact location unkown).
He said that his boost was normal at the time. He pulled over and let it cool off for a while but again jumped to over 1600 within 1 mile. Stopped and called a tow truck.
Any ideas?
Old Sep 18, 2005 | 09:22 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
damn. even four seconds above 1800* is enough to dramatically shorten the life of the engine.... i bet the pistons have begun to start melting, if it actually got to 2000* by the way, the turbo is destroyed too, the vanes begin to melt around 1250* actual temperature, same with pistons (aluminum). so the EGT would have to be around 1900 for that to happen. hopefully it is just a malfunction that read that high. even pulling trucks dont get to 2000*
Old Sep 18, 2005 | 09:33 PM
WA.Ranger's Avatar
WA.Ranger
I wonder if it has a post turbo gauge, or does that matter with the Edge?
Old Sep 18, 2005 | 09:35 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's nearly impossible he was seeing 2000 actual given the situation, and pretty unlikely that there is a problem with the thermocouple itself. That leaves the wiring and the gauge as the most likely sources.
Old Sep 18, 2005 | 10:42 PM
444dieselrod's Avatar
444dieselrod
Originally Posted by strokin_it7.3
the turbo is destroyed too, the vanes begin to melt around 1250* actual temperature, same with pistons (aluminum). even pulling trucks dont get to 2000*
Actually the Turbo vanes are Tungsten Steel, melt at 2200*+
and Pulling tractors do get to 2000*, but everything is coated with ceramics.
Most likely a wiring problem, my tranny temp was freaking out one day, turned out to be a bad ground at the amplifier box.
Diesel Rod
Old Sep 19, 2005 | 12:44 AM
touchofgrey's Avatar
touchofgrey
Diesel Rod
I thought I had something to rebutt....but I don't......never mind.
Old Sep 19, 2005 | 01:10 AM
NickFordMan's Avatar
NickFordMan
Theres no way he saw 2000+ in that type of situation.
Old Sep 19, 2005 | 06:02 AM
PowerstrokeJunkie
yeah i know that it was most likely a wiring problem and that it would never happen under extreme conditions, but oh well.
about the vanes, i didnt know that. i heard someone here a while back say that they were aluminum, and would melt along with the pistons.
and i specified pulling TRUCKS not tractors. ive seen tractors in action and man is it something!
Old Sep 21, 2005 | 10:05 AM
Hightempsilicone
Bad thermocouplers guys.
Thanks!
Old Sep 21, 2005 | 08:10 PM
cookie88's Avatar
cookie88
FTE Emeritus
Wow. That's a first for me....on a 7.3 anyways. How many of those 220,000 miles has the thermocouple been installed?
Old Sep 21, 2005 | 10:07 PM
Hightempsilicone
120 miles since the edge/attitude was installed!
Old Sep 21, 2005 | 10:15 PM
amish77's Avatar
amish77
may be a bad unit, or when the seals plew they messed it up. 2k is a lot of temp. you can do metal soldering at that temp. Needless to say the metal in the area would be annealed.
Old Sep 21, 2005 | 10:46 PM
superrangerman2002's Avatar
superrangerman2002
Just think what a dusted turbo would look like if those blades were really aluminum.
For analogy sake, its like comparing a aluminum boat prop to a stainless steel prop.
The steel prop will take a severe beating any show little wear and vice versa on the aluminum.
Old Sep 21, 2005 | 11:22 PM
barebackjake's Avatar
barebackjake
bad thermo is what made it show so high, stock injectors cant make enought fuel to gettter that hot. plus forged pistons melt at 1800ish degrees. there would be nothing left of the motor if it got that hot. if al in a gas state made it out of the motor it would look like a greyish powdercoat on the impeller vains and that kinda heat even with stainless exaust impeller it would have started to melt the corners off the impellers.
i was thinkin bad thermocouple, bad power source, bad ground. diprocal had a rash of bad thermos a year or so ago. ive had one go haywire before that was a autometer. it was in my 94.5 for about 300k miles when it went wacky. autometer still replaced it for free.
Old Nov 19, 2005 | 11:28 PM
GaStroke29's Avatar
GaStroke29
take off the edge it is a piece of shaznat. get a diablo sport from motorhaven
