casting numbers
Old Sep 17, 2005 | 05:59 AM
kcox0360's Avatar
kcox0360
Cool casting numbers
I have a block that was given to me I was told that it was a 360. I have numbers off of it. Under the oil filter adapter was 8F18 or 8FI8 with EI stamped above it. left front has 30 DIF on it, and rear of block has 352 29 stamped on it. If anyone has any information please let me know.
Old Sep 17, 2005 | 09:47 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
8F18 is the date code of 68/June/18th. DIF is the foundry (dearborn iron foundry) Measure the bore. 360 and 390 blocks have the same bore and are basically the same. I got your email and sent you a reply. A block without casting numbers is a pretty common thing to find. G.
Old Sep 17, 2005 | 10:10 PM
kcox0360's Avatar
kcox0360
does the 352 stamped on it mean anything?
Old Sep 17, 2005 | 11:35 PM
fordeverpower's Avatar
fordeverpower
yes and no! The 352 was the first FE i believe in 1958. Otherwise, no its means nothing. A 360 and 390 are the same thing. Ford stamped a lot of blocks with 352 back in the day, then they went to the mirror 105 crap. This same thing got me when i bought my truck and saw 352 stamped on the block when it was a 390.
Old Sep 18, 2005 | 05:16 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
And to add to what fordeverpower said also some early castings had no 352 or reverse 105 on the block. The 332 was the first FE back in 58. It is a 68 casting though with the DIF foundry mark on it. You can check the gap of the cyl wall cores to see what kind of thickness ther block has. 68-69 were some good years for castings. G.
Old Sep 18, 2005 | 05:26 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Forgot to add you can check the block to see if it's a hd casting. Use this link.....www.428cobrajet.org click on component ID them blocks. It will show the diff between the std 2 web castings and the HD CJ style castings with the 3 web cranksaddle and beefy crank area. G.
Old Sep 18, 2005 | 06:28 AM
kcox0360's Avatar
kcox0360
does the 390 and 360 blocks have the cross-bolt holes located on the bottom of the block like the 428?
Old Sep 18, 2005 | 07:07 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
No and that's on the 427. But some blocks have the crossbolt nubs or bosses which are the cast in provision to crossbolt the block. Just 427 crossbolt caps and spacers are needed plus the machine work to install them. Any block can be crossbolted like the 427's. Blocks without the crossbolt bosses just use a longer spacer. Pro-Gram eng also sells a set of billet steel crossbolt caps for $344. OEM sets of caps are selling for more on ebay. G.
Old Sep 18, 2005 | 07:37 AM
kcox0360's Avatar
kcox0360
thanks I was just wondering b/c I have this block and it has the bolt holes on the bottom like the 427. So, I am guessing that it is not the 360 or 390.
Old Sep 18, 2005 | 08:45 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Are there three on each side??? If so it may very well be a 427 or at least a crossbolted block. If you see only two holes on one side and they don't go through the block it's where the J bar was attcahed to the block at the factory for the assy line.....all FE/FT blocks have those two holes. G.
Old Sep 18, 2005 | 05:43 PM
kcox0360's Avatar
kcox0360
didn't have time to measure the bore, but did find a "390" stamped on the driver side front. It is located right in front of the oil filter adapter. Does this mean anything?
Old Sep 19, 2005 | 12:49 AM
kcox0360's Avatar
kcox0360
I found a "10929" stamped on the block also
Old Sep 19, 2005 | 04:21 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Well with the block stamped 390 it's probably a 390 block. Ford did stamp some blocks in that area sometimes. Could have also been from a rebuilder also. Same with the number you found. Partial vin's were stamped on the back of the block staring in 68. Again not all blocks were stamped but as time moved on seemed to be a more common practice. Could also have been a ID number from a rebuilder at some m point. If you measure the bore you'll confirm what it is.......G.
Old Sep 19, 2005 | 05:26 AM
kcox0360's Avatar
kcox0360
the pistons are also stamped 40 does that mean it is bore .040 over? I would also need to measure the connecting rods to see if it is a 360 or 390 wouldn't I?
Old Sep 19, 2005 | 02:41 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Good chance the 40 is .040 slugs. If you have the crank and rods give me the numbers off them. I can tell you exactly what they are. The crank number might be a full Ford casting number ex: C6AE-A or a 2 or 3 digit one like 2U, 3U, 2TA. The crank number is on the edge of one of the counterweights. The rod numbers are on the side of the rods. G.
lilorbie
Nov 21, 2016 10:35 AM
1990FRANKENTRUCK
13
Oct 26, 2016 06:53 PM
maverick600
Sep 26, 2016 09:33 PM
another-user
Jul 20, 2016 04:35 PM
jmadsen
17
Nov 21, 2013 06:30 AM
