NEW DP touching firewall??
Old Sep 16, 2005 | 09:09 AM
wycowboy's Avatar
wycowboy
I jjust got done insataliing my new 3" DP from DPP Should have asked about wich end of the old one to cut off first but any way . it looed like if I cut the bottom oof I cold slid it out the top. no luck
Well I had to bend the heck out of the pinch weld to get the new one in. but it is still touching the firewall. I think that is what is making my truck loiuder in the cab but I am mainly worried about fire danger from that 1000 deg exhaust runner that close to the floor boards.
Do I need to take the dp off and make more room so it dose not touch??
Tanks for the help J
PS it seem like I'm seekinf a big dropin EGT's!! or its the cold weather but I like the thought of it being the DP!
Old Sep 16, 2005 | 04:54 PM
Mark at DPPI's Avatar
Mark at DPPI
Wycowboy,
Yep you need to make more room for the pipe, also make sure the pipe is angled correctly if you set it up wrong it'll make clearance a big ole PITA! The EGT drop you're seeing is the down pipe trust me on that one seenit maaannnyyy times before !
Mark @ DPPI
Old Sep 16, 2005 | 08:38 PM
wycowboy's Avatar
wycowboy
Thanks mark. I'll need to look at it some more If I have to bend the pinch weld some more it'll be tough. any tricks ??
P.s mark how much clearance do I need min.? 1/4"??
Old Sep 17, 2005 | 08:57 AM
barebackjake's Avatar
barebackjake
just gotta beat on it some more. can you see where its touching right now? you might be able to stop it from touching by roating it downward a little bit. just gotta kinda play with it. the insulation thats on the bottom of the truck is foil backed mineral wool that wont burn. but just the cab noise from it touching gets kinda irritating
Old Sep 17, 2005 | 06:29 PM
wycowboy's Avatar
wycowboy
Thanks Jake .I'm herding out there right now with 2x4's my 2lb shoeing hammer, and steel bars. it'll be fun J
Old Sep 17, 2005 | 10:15 PM
barebackjake
not gonna get far with that little roundin' hammer the 8lb sledge works great. if you know someone with a portapower of a place to rent one that is the ticket thats how i got that 4" in my truck
Old Sep 17, 2005 | 11:02 PM
wycowboy's Avatar
wycowboy
no porta power around here that I know of but it seems as if the 4' crowbar did the trick it looks like I could get a 3 1/2" inthere now.
how did you get any room to swing the 8 lb sledg? thanks J
Old Sep 17, 2005 | 11:28 PM
barebackjake
was hittin the end of a 2" sch 40 pipe with a cap on it. if i had to do it on another truck to get the 4" in i would pull the carpet out and cut the section of pan out reshape it and weld it back in. the floor board on that side is kinda oddly shaped and i cracked it but i have a ceramic blanket on the underside and the dp is ceramic coated.
Old Sep 17, 2005 | 11:48 PM
444dieselrod's Avatar
444dieselrod
We used a 16' 2"x4" against the VC to bend the pinch weld and the firewall, eventually we broke the 2x4, but nothing touches, and the VC isn't bent. had to take hood off though.
Diesel Rod
Old Sep 18, 2005 | 07:50 AM
wycowboy's Avatar
wycowboy
rod , help me out with the acronime?? wat do you meen by VC?
Old Sep 18, 2005 | 11:21 AM
barebackjake
im guessin valve covers.......
oh yeah thats right i forgot yall have autos, theres more room to play with the 5 speed.
Old Sep 18, 2005 | 04:56 PM
wycowboy's Avatar
wycowboy
sounds good to me
OldWoodsDiesel
18
Jan 4, 2013 06:51 AM
savage250
Jan 5, 2011 06:30 PM
XBAJBUSX
Dec 14, 2010 02:53 PM
JethroF250
27
Jan 1, 2009 11:38 PM
Savafords
Oct 30, 2004 07:51 AM
