Truck Tents
Old Feb 19, 2001 | 04:36 PM
dust3's Avatar
dust3
Truck Tents
Has anyone bought or used any of the truck tents that are available? I want to know if they're worth buying or if I should stick with my trusty ground model.
Dustin
Old Feb 20, 2001 | 05:24 AM
bgodkin's Avatar
bgodkin
Truck Tents
A guy at work had what was called a wildernest on his Truck. Looked like a regular cap but folded out into a rather large pop-up camper. It was really cool. The only downfall to it was it was heavy and had the same limitations as a cap does(and then some) as far as room inside. I have seen some of the tents that hook to the back of the rigid bed covers though. Look pretty good to me!
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old May 3, 2001 | 09:24 PM
dust3's Avatar
dust3
Truck Tents
I'm still pondering getting one like these at, http://www.sportztrucktent.com
"Somebody put this together, I must be able to take it apart! "
Dustin
Old May 4, 2001 | 09:34 PM
jamden's Avatar
jamden
Truck Tents
If I was going to use one of those truck bed tents I would want to make sure that the tent's rain fly was outside of the box rails all the way around. Seems to me that if it started to rain hard and the fly was directing the runoff inside the box you and your stuff would be floating in no time. Even with the tailgate down and the truck slopping rearward I can see the rain filling it faster than it can run off.
1992 F150 Supercab SB 4x4 302 AOD 3.55 31x10.5 All Terrain on Ford 15x8 Ralleys
Old May 13, 2001 | 08:42 PM
proeliator's Avatar
proeliator
Truck Tents
Old May 15, 2001 | 09:52 AM
wolf189's Avatar
wolf189
Truck Tents
my girlfriend picked up a Sportz Truck Tent last summer for our regular weekend camping trips and it has worked out great for us. The rain fly extends far enough out that i've never been concerned about rain getting inbetween the bed and the tent, and even if it did there are two factors that make the issue irrelevant, first, if you park on a very slight uphill grade any water would run out the back of the bed before it could accumulate, and second, the lower portion of these tents (everything that is below the bed walls) is made of a heavy, waterproof, plasticized canvas-type material (kinda like those heavy-duty reinforced plastic tarps) so even if the bed did start to fill with water we wouldn't notice or really care much.
Set-up time is much quicker than any comparable sized regular tent, and it stays cleaner/drier overall in wet weather cause it's up off of the wet ground (have seen fellow campers in regular tents get partially washed away by quick torrential downpours that simply flowed underneath the truck (and us).
In summary, i would highly recommend these type of tents... =)
wolf189
'93 F150 4x4 Regular Cab, Long Bed - 4.9L I6 w/5spd Manual
no mods... yet...
http://www.pamba.thinkhost.com/images/bigblue.jpg
peterbilttrucker
New Member Introductions
Apr 29, 2009 10:19 AM
FordSVTCobra
Jun 11, 2007 06:26 AM
polarbear
27
Mar 2, 2006 12:45 AM
oleblue70
Jan 7, 2001 01:02 PM
