Sponsored by: Auxito
cabin airfilter
Old Sep 15, 2005 | 09:25 AM
fiend138's Avatar
fiend138
cabin airfilter
Does a 2003 F150 KR come with a cabin airfilter?
Thanks!
Old Sep 15, 2005 | 12:01 PM
MrBSS's Avatar
MrBSS
I'm fairly sure the answer is "No", but you can add one. I bought a Ford Accessory kit which is no longer available, but some have just cut the plenum and added it; check the Heating and A/C Forum.
Old Sep 15, 2005 | 05:03 PM
ccoram's Avatar
ccoram
They don't come with one - its a dealer installed option. If you want to add one, just buy a filter and cut the slit out in your heater box under the RH side of the dash. Its a slit the same shape as the filter - check under there you cant miss it. Real thin plastic - I poked a pocket screwdriver through mine and then worked the screwdriver around the door until the plastic popped out and just insert your filter.
Old Sep 16, 2005 | 08:23 AM
fiend138's Avatar
fiend138
Is it worth the time/ effort?
Old Sep 16, 2005 | 03:15 PM
ccoram's Avatar
ccoram
Well it only takes about 10 minutes once you get it figured out. As far as is it worth it, you take the old filter out after about 12,000 miles and you'll say yes definately. As far as can you tell its in there, IMHO no.
Old Sep 16, 2005 | 07:26 PM
rtpalin's Avatar
rtpalin
Which filtre fits the 97 to 03 truck
Rick
Old Sep 17, 2005 | 10:21 PM
ccoram's Avatar
ccoram
CF1007 is the GKI number. You can get them at Oreillys.
Joe Seatter
Escape & Escape Hybrid
Jun 17, 2016 10:47 AM
Jaime74656
1997 - 2003 F150
Jul 23, 2015 05:28 PM
CharlaineC
Oct 26, 2014 10:16 AM
Skip1970
Feb 8, 2011 06:09 PM
574ford
26
Feb 9, 2008 06:45 PM
