Front Wheel Bearings?
Old Sep 14, 2005 | 09:52 AM
fta9633's Avatar
fta9633
I have a 96 f150 4X4 with SuperWinch manual hubs. I notice a squeaking noise as I start to drive that may be from both front wheels. The noise continues at all speeds. Brake application does not alter it nor does engine speed. It is road speed dependent. Is there some way to lubricate the hubs or wheel bearings? It seems to have appeared after driving through 12-18" water caused by a thunderstorm. Any ideas are greatly appreciated!
Old Sep 14, 2005 | 10:52 AM
MustangGT221's Avatar
MustangGT221
Well the wheel bearings and axles probably need to be re-lubricated.
The axles just have gear oil, where as the wheel bearings are packed with grease. You'd have to take the hub and rotor assembly off.
Old Sep 14, 2005 | 11:33 AM
andym's Avatar
andym
You also may have gotten water in the u-joints and tie rod ends. If they are greasable, I would grease them soon - it pushes the water out. If they aren't, then keep an eye on them, they may start making noise soon.
Re-greasing wheel bearings is pretty easy. What I would do is go to Jeff's Bronco Graveyard and buy four new bearings (inner & outer on each side) and take them to a brake shop and have them greased. The tool they have to do it works much better than what you can do by hand. Then just swap them out when you get home.
Old Sep 14, 2005 | 11:40 AM
fta9633's Avatar
fta9633
I will give that a try at get back. Thanks for the advice
Old Sep 17, 2005 | 07:03 AM
96f150's Avatar
96f150
Squeak
Ya know, I have a 96 also, and I have had the same issue. Mine turned out to be the innner grease seal, whenever it gets really wet, it then squeaks afterward. I have tried to run a thin coat of lithium grease between the 2 mating sufaces, but to no avail, I ended up having to replace it. I think it was about $25 for the seal.
Rich
944_s_type
Feb 21, 2014 04:43 PM
Ekkehard
2004 - 2008 F150
Nov 4, 2012 02:58 PM
Abzack
Dec 1, 2009 01:36 PM
jcheadle
Dec 12, 2008 12:03 PM
aebrown
Jan 8, 2008 09:26 AM
