recall notice, I thought this was only the newer trucks.
I first found out about it here... https://www.ford-trucks.com/forums/s...d.php?t=409706
after that I googled it and called my ford dealer mon. morning and tommorrow I'm taking it in the morning to drop it off and they said that they're going to "waterproof" the plug, then in october when the parts come I have to take it back and they'll fix it. I told them mine had stopped working 2 months ago and I also said that I disconnected the switch. So anyways 2 months ago I went to drive it at night and I didn't have any dash lights or parking lights so I found which fuse it was and replaced that and fixed it. Also the same night I went to use my cruise control it would not work and I had already read on here (fte rules btw ) about the switch that goes bad so I unhooked it, so here it is 2 months later and finally they come out with the recall. What gets me is that they knew about it before when they recalled the last bunch. I love my truck and all but ford really let the ball drop on that one
FORD says:
<!--StartFragment -->"Ford has worked closely with NHTSA to investigate this issue. Ford's investigation found that brake fluid may leak through the speed control deactivation switch into the speed control system electrical components, potentially corroding them. In rare cases, the corrosion in the electrical components can lead to increasing resistance and higher electrical current flow through the system. Together, these conditions could lead to overheating and, possibly, a fire at the switch. This system interaction is the result of the close proximity and orientation of the speed control components in the recalled vehicles."
Did anybody read what they said?
I do not think so.
1. How can brake fluid leak though a switch and get into an another system?
Wires are carriers of current, not liquid.
2. If it did do this they are not doing anything to the speed control components.
The only component in the area is the Speed Control Servo.
3. Increasing the resistance reduces the current flow and will not increase it.
4. A fire at the switch, what is burning?
Is brake fluid flammable, the container it comes in does not say so.
Are the wires over heating and burning? You mean they can not carry 15 Amps.
I own one of these and this all doesn’t sound right to me. Do the Ford Trucks catch on fire and burn? Yes they do but I do not think that NHTSA and FORD are in the right place.
I am more worried about that large unprotected, always hot battery cable running from the battery down along side the engines exhaust manifold to the starter. This would start a fire in a hurry on a "V" type engine. Any inline 6's burned up?
Why did they have to change to this?
I do not think so.
Best I understand, the switch can short to ground through the brake fluid when the internal diaphragm breaks, creating a short circuit. The higher resistance means more heat, and with a possible short to ground, it is certainly possible to start a fire. The wires there are likely not designed to carry 15A, because they are just signal wires. The computer only needs to see a voltage to know the switch is closed.
Both of my trucks are covered.
If you want to check to see if your rig is covered then click on the link below, scroll down a bit and type in your VIN#
http://www.ford.com/en/vehicles/owne...ls/default.htm
lol now this is some funny stuff... I went this morning to drop my truck off and tell them that I had already unhooked the switch 2 months because the cruise stopped working and I read on the internet that if it stops working to disconnect the switch. So then he tells me it will only take a few min. for them to tape it up and "waterproof" it. So anyways we go into parts to get some heater hoses for dads truck and the same guy goes outside and pops the hood and comes back and says that the plug is not there and he's going to find out what they're gonna do about that. Then I tell him again that it stopped working 2 months ago and I unhooked it and now the plug must've fell off the wires. So anyways he goes inside to talk to someone about it and I'm like huh? I know the plug was on the wires really good and how could it just fall off so I went over to the truck and fish around underneath the master cylinder and pull everything up and bam there it is. So I go back inside to wait on the "dipstick" to get done talking to whoever it was in the office. He comes out and I tell him I found the plug and it was underneath the master cylinder and he said that it would take a little longer because they are going to replace my switch that is leaking. So when me and dad was getting ready to leave I told him I better put the plug where I know they can find it so I wedged it in between the switch and the reservoir so it was right on top. So I'm thinking if they can't find it now somethings wrong. So we left and an hour and a half later they called and said they was done and I could just drive off in it. Well all in all I got free switch and my cruise works again but I still have to take it back in october for them to put the circuit breaker on it.
The problem with this switch is first of all if you take the connector off and check across it with a multimeter, you will see 12 volts at all times whether the key is on or not. Inside this switch is a pizioelectric pressure element mounted to a very thin diaphram. When you press the brake pedal the fluid pressure in the master cylinder opens the switch which shuts down the cruise control. When the diaphram develops a crack over time as all diaphrams do, you now have a 12 volt heater element immersed in brake fluid. The fluid eventually boils and presto you're up in flames.
Gage2502
1999 to 2016 Super Duty
07-21-2011 07:34 AM
superduty4x4
32
10-15-2009 08:24 PM
