5.4 crankshaft
Old Sep 13, 2005 | 01:44 PM
Marcusm's Avatar
Marcusm
5.4 crankshaft
I tried searching for this and couldn't find an answer. I am wondering if the crankshaft in a 1999 5.4 2V Expedition is forged steel? I'm thinking it's a steel crank in all 5.4 trucks, but again not 100% sure.
Old Sep 13, 2005 | 02:34 PM
l-m tech's Avatar
l-m tech
the crankshaft from a windsor has 8 bolts holding the flywheel on and is forged.the 6 bolt romeo isnt.
Old Sep 13, 2005 | 03:29 PM
LxMan1's Avatar
LxMan1
Welcome. I think only the Cobra 4V engines have a forged steel crank. Possibly the Lightnings too. Unless you are turning over 6000rpm, the cast crank will work fine.
Old Sep 13, 2005 | 03:46 PM
Marcusm's Avatar
Marcusm
Thanks for the info. The motor was just recently pulled out. It is almost ready to go the machine shop, but still waiting for the bottom end to be broken down. The motor it self will end up being a procharged 4V. I want a very strong bottem end.
Old Sep 13, 2005 | 06:35 PM
ford390gashog's Avatar
ford390gashog
you can not bore that engine over .020 just to let you know. most can not even be rebuilt.
Old Sep 13, 2005 | 11:13 PM
LxMan1's Avatar
LxMan1
I would look into a Lightning crank since it is going to be supercharged. You might check out dssracing.com. They have many good parts for these engines.
Old Sep 14, 2005 | 09:20 AM
Marcusm's Avatar
Marcusm
The motor originally had 32,000 miles, dropped a valve. Had walls checked and they are good to go. The crank (eight bolt flywheel) I found out from the shop, is a steel crank. Great condition. Now that I Know the block is standard I can order my other internals. Thanks for the website, I'll check them out.
Old Sep 14, 2005 | 07:40 PM
fordiesel69's Avatar
fordiesel69
Why can't you bore them????? If not, can you bore big and resleeve down to the correct size?
Old Sep 14, 2005 | 09:17 PM
ford390gashog
because there is nothing there to bore out. these are not the old enignes which could be bored .060 over these can barely take a .020 and even then you risk going to thin.
Old Sep 16, 2005 | 07:48 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'm sure they can be sleeved, but the last time I looked, even a V10 block was less than the machine work for 8 sleeves at something like $100/sleeve.
Ford list for a 5.4L block is $555.75 (fordparts.com $408.48), V10 is $975.72 (fordparts.com is $717.15)
dwh039
6.2L V8
Nov 16, 2016 07:47 PM
OILBURNER
Modular V8 (4.6L, 5.4L)
Nov 3, 2016 11:26 AM
H60_Driver
1997 - 2003 F150
Oct 26, 2016 11:02 AM
Bigshep
2015 - 2020 F150
Aug 21, 2015 05:05 AM
irsmun
Aug 2, 2015 11:10 AM
