Where is the....
Old Sep 13, 2005 | 10:50 AM
ag-ford-4x4's Avatar
ag-ford-4x4
Where is the....
CAC tube, and inlet y-tube noted in the exhaust in cab TSB?
Also, what do they look like, so i can find and look at them?
I hear a lot about these, but have no idea what is which in the engine bay....
Old Sep 13, 2005 | 11:47 AM
3/4ER's Avatar
3/4ER
CAC is the large (3in.) black pastic tube that goes from the intercooler to the intake. The Y turbocharger inlet pipe is located between the turbocharger, and the firewall. The left, and right exhaust manifolds converge into the Y pipe.
Old Sep 13, 2005 | 01:17 PM
ag-ford-4x4
What is the metal tube with the blue rubber connectors/hose clamps??
Old Sep 13, 2005 | 02:35 PM
Hayapower!'s Avatar
Hayapower!
Both 'CAC' ducting... One is the intercooler inlet (metal) 'turbo comp. outlet', and the other is the intercooler outlet (plastic) intake/eng. inlet..
...................HP.................
Old Sep 13, 2005 | 04:41 PM
ag-ford-4x4
are those what leak and cause the exhaust smell in cab if its not the y-pipe?
Old Sep 13, 2005 | 04:54 PM
bnmccoy's Avatar
bnmccoy
There is a TSB with a procedure to first warm the engine up; shut it off; remove the EBP, exhaust back pressure sensor; hook a 'smoke machine' up to the EBP tube in place of the EBP; look for leaks. If leaking between the exhaust manifold(s) and head then install exhaust manifold gasket(s) where none originally exist.
CAC, charge air cooler; Intercooler to us normal folks.
Bob
Old Sep 13, 2005 | 08:44 PM
3/4ER's Avatar
3/4ER
No, the intercooler pipes, most commonly the one from the intercooler to the intake have a tendency to blow off.
The Y pipe is where the exhaust manifolds converge into a single outlet to the turbocharger. These pipes are convoluted (similar to the hook up on a gas stove), to allow the pipe to be flexible, thus the possibility of cracking.
Cameo 57
Apr 10, 2014 11:11 AM
95schauf
Feb 10, 2013 10:00 AM
jvaski
1997 - 2003 F150
May 28, 2010 09:30 PM
