7.3 is consuming coolant....
Old Sep 13, 2005 | 01:24 PM
touchofgrey's Avatar
touchofgrey
Originally Posted by Rancha9
Just thought of something.... If there was a leak from say, the oil cooler, but it wasn't very big, would the antifreeze in the oil evaporate off? Or, at least, the water in the antifreeze? Reason I ask is, I just went out and checked the oil, and it appears that the truck has magically made some. I'm running it right now to see if I can catch a milkshake in action...
I thought about the oil cooler.......but you had stated that the oil was ok......so I didn't mention it. I had one of the O rings go bad on mine once.....but the oil did show signs of contamination.....plus it was high. Your water is going to be in the bottom of the pan.....it may not turn the oil milky with the volume we're talking about. Pull the drain plug, and drain about a quart......and see what it looks like.
ajg617
Nov 9, 2014 10:06 PM
RLICHT
23
Dec 8, 2013 08:22 PM
Kdr358
32
May 26, 2013 12:43 PM
mobilefleet
1983 - 2012 Ranger & B-Series
Nov 18, 2005 07:51 AM
BrianA
1997 - 2003 F150
17
Jan 6, 2005 07:04 PM
