Sponsored by: Real Truck
Towing an automatic long distances?
Old Sep 12, 2005 | 06:00 PM
bigsub's Avatar
bigsub
Is it bad to tow an auto long distances by just putting it in neutral?
Old Sep 12, 2005 | 06:07 PM
Beast12's Avatar
Beast12
It is not the best thing to do. If it is 4x4 and has a transfer case with a lever (not ESOF) you can put that in neutral and you will be fine.
If it is 2 wheel drive then I would highly recommend removing the driveshaft.
Good luck!
-Matt
Old Sep 12, 2005 | 06:14 PM
Leader's Avatar
Leader
Yes it is VERY bad.
Get a trailer or disconnect the driveshaft..
If two wheel drive you can get by with a dolly.
Old Sep 12, 2005 | 06:31 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Don't do it. Especially if 4X4. If 2X4 you can take drive shaft off. On my 04 it says not to tow right in the owners manual.
Old Sep 12, 2005 | 07:13 PM
bigsub's Avatar
bigsub
Does anyone know the technical reasons? What does it do to the transmission? What if you leave the engine idling does that help the tranny oil itself? Just a thought.
Old Sep 12, 2005 | 09:42 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If the tranny is good, and the fluid is good, there's no practical reason that you can't let the engine idle and then tow it. That wouldn't hurt it.
The problem is when the torque converter isn't turning, the oil isn't circulating in the transmission. That will certainly burn up an automatic very quick.
Even some manual transmissions have oil pumps in them, and if the engine isn't running, you better remove the drive shaft before towing it.
Either 4x4 (in 2-wheel drive) or 4x2, remove the rear driveshaft and you'll be fine. (if the driveshaft slides into the tranny/transfer-case, leave it in place or you'll leak out all the fluid and really mess up someone else's day).
When removing the driveshaft, index it (mark it), on both ends preferably, to make sure it lines up exactly like it did before removal.
Old Sep 13, 2005 | 08:49 AM
bigsub's Avatar
bigsub
So could I plumb in an electric pump to pump the fluid while towing?
Old Sep 13, 2005 | 09:16 AM
krewat's Avatar
krewat
That's ingenious, but, IMO, impractical.
First, how much pressure does an auto tranny produce? And how much pressure would you need to move the fluid through a pump that isn't moving? If it would even move through the pump?
Easiest thing, drop the driveshaft - in my Superduty, it's four bolts to disconnect the driveshaft from the rear-end. It's about the same complexity for most other vehicles. Lots easier than finding a high-pressure pump and plumbing it.
Old Sep 13, 2005 | 09:22 AM
IBeam's Avatar
IBeam
One quick note here, if you drop the drive shaft, do your self a favor and just take it loose from the axle, then leave the one end in the Trans/Trans Case, then secure it very good up under the body. If you pull the shaft all the way out, you leave a trail of oil every where you go. Not to mention what would happen if you are pulling it in dirt or rain.
Old Sep 13, 2005 | 09:23 AM
alchymist's Avatar
alchymist
"Mifflin Clay"
Unless I am dumber than I thought, the manual 4X4 transfer case can be shifted to neutral to allow the vehicle to be towed.......... (Course I could be dumb enough to not realize I am dumber than I think I am)
Old Sep 13, 2005 | 09:25 AM
Leader's Avatar
Leader
True the pump would circulate the fluid but it also needs to be cooled.
What are you trying to do here, tow it behind a moterhome or just get it from point A to point B ?
Old Sep 13, 2005 | 09:31 AM
krewat's Avatar
krewat
You are absolutely correct. And even with an auto 4x4, with 4x4 OFF, you can disconnect the REAR driveshaft and everything would be fine.
Old Sep 13, 2005 | 10:03 AM
Casey's Avatar
Casey
Yes you can. Remco makes a pump specifically for this. www.remcotowing.com
Old Sep 13, 2005 | 10:04 AM
Leader's Avatar
Leader
Not so sure about that. Some transfer cases now need cooling just like transmitions. Better to check with the Mfg. before you do it.
As far as I know only some Jeeps can be towed with 4 wheels on the ground & automatics.
Old Sep 13, 2005 | 10:34 AM
krewat's Avatar
krewat
If you disconnect the driveshaft from the rear differential, and the transfer case is in 4x2 (2-wheel drive) and the front hubs are not locked (or whatever it is up there on this vehicle we're talking about), the transfer case is NOT involved.
That Jeep you're talking about probably has a neutral in the transfer case, and yes, you can tow that.
ANY automatic should NOT be towed with the output shaft spinning and the engine NOT running.
That Remco pump sounds intriguing...
