are these codes important???
Old Sep 11, 2005 | 09:20 PM
turboguy's Avatar
turboguy
I pulled codes, and I think I got...
44 Thermactor Air Injection system inoperative (Right side).
and
52 Power steering pressure switch always open or closed
I dont know how to troubleshoot either of these problems... Or what they really mean.... I know that the Thermactor pump is your smog pump... but IM not sure what could cause it to fault out... I replaced the EGR and the codes still there...
I dont know much about the power steering... its seems like a fairly simple system... and I have no idea where the "Switch" would be. and I have a feeling its some type of electrical circuit and not a real switch...
Any help would be appreciated.
Old Sep 11, 2005 | 10:04 PM
MustangGT221's Avatar
MustangGT221
Could be a hose or vacuum line to the TAB and TAD solenoids (those do-hickys next to the coil on a V-8), air pump, etc etc...start with the simple stuff...
That is important because it supplies oxygen to your cats in the exhaust, and w/o that oxygen those cats will fail.
Old Sep 12, 2005 | 10:12 AM
handyman43358's Avatar
handyman43358
Did you turn the wheel a half or full turn when you did the test? Thats probably why you got a code 52.
Old Sep 12, 2005 | 09:17 PM
xltlariat87's Avatar
xltlariat87
the code 52 i wouldn't be to conserned with it. my'87 5.0 has had the same code for about a year now.
Old Sep 12, 2005 | 11:49 PM
turboguy's Avatar
turboguy
FOund the reason for my 44... One of the vacume lines from the TAD solenoid is disconected.. I found it flopping around Near my water pump... its a beige line... I have NO IDEA where I goes!!! I will take pictures tomarrow... it is the bottom line that conects the the sensor...
Old Sep 14, 2005 | 12:12 AM
turboguy's Avatar
turboguy
Posted pictures in my gallery... Kinda hard to see.. Please help.
Old Sep 14, 2005 | 06:58 AM
EPNCSU2006's Avatar
EPNCSU2006
On my truck, that vacuum line goes to a valve located just at the outlet of the smog pump. Basically directly below where you are holding the line in the picture. There should be a nipple on top of the valve for the vacuum line.
Old Sep 14, 2005 | 04:29 PM
turboguy's Avatar
turboguy
YES! Found it.. thanx so much... I reset the computer and after a wekk I will check to make sure the codes gone.. thanx!
88 f150
Sep 23, 2021 07:55 AM
Colt45ws
Dec 24, 2009 10:27 PM
coplin
16
May 7, 2007 11:09 PM
bebad96
17
Jun 16, 2004 12:00 AM
Katt
May 24, 2000 06:47 PM
