pre/post luber
Old Sep 11, 2005 | 08:45 PM
fordman13's Avatar
fordman13
pre/post luber
looking at buying a pre/post luber . the kit has a t-fitting at the oil pan drain plug ,a hose hooks on there and goes to the pump ,a hose comes out of the pump and i don't know where to go back into the engine, maybe the sending unit , the dealer of the unit said that there is a test port where i could enter back into the engine but i can't find either one. need help pictures???? anyone else running a preluber? thanks
Old Sep 11, 2005 | 10:03 PM
Aarkie's Avatar
Aarkie
I looked a long time ago but did not save any of the information. If I remember right they were some problems with the pump, some of the others may be able to verify this. The pump was noisy and if the pump was mounted higher than the motor the seal would leak down onto the motor. If it is not piped in correctly you bypass the oil filter when it is running. It sounds good but they still had a few bugs to work out a year or so ago. Let us know what you find out.
Old Sep 12, 2005 | 03:35 AM
Crash687's Avatar
Crash687
does this help?
http://www.pre-luber.com/installoverview.htm
Old Sep 12, 2005 | 09:17 AM
satcom40's Avatar
satcom40
That the one I order and it is a little noisy but it works fine, no problem with mine.
Old Sep 12, 2005 | 05:41 PM
fordman13's Avatar
fordman13
to satcom40
what brand did you buy? where did you return the oil back into your motor?
Old Sep 12, 2005 | 07:32 PM
satcom40's Avatar
satcom40
I bought it online from Pre-lube.com. The pre/post luber and there fliter (output of pump go to fliter) then to Check value too a TEE, off the tee #1. Port I when to the Oil Gaurd filter and than back to the filler cap the #2. Port off the tee go the Alumium Oil filter cover, I tap the top of it with an 3/8 npt. I am at work now can sent you a drawing in a day or two if you like. John w/ help from Rick Braden
Old Sep 12, 2005 | 08:57 PM
fordman13's Avatar
fordman13
drawing
a drawing would be great A++++++ send to fordman@icx.net thanks so much.
Old Sep 17, 2005 | 02:14 PM
fordman13's Avatar
fordman13
satcom40
satcom40 ,did you get my e-mail address? for the drawings.
