C6 in a Highboy
Old Sep 11, 2005 | 07:53 PM
cdorroh's Avatar
cdorroh
C6 in a Highboy
'68 F250 4x4, 390-4spd
I have been planning a tranny swap from my np435 to a c6 for most of the summer, collecting and installing parts that I can for now. Well, my clutch assembly finally fell apart on Thursday, so the project has moved up on the to do list.
I have found a couple of C6 trannys that seem re-buildable, but different years have different tailshafts / tailshaft housings. Any thoughts on which would be better in the '68 Highboy?
I found a '73 F100 and a '69 F??? in the junkyard over the weekend. The '73 F100 has a longer tailshaft / housing, and the '69 has a much shorter tailshaft / housing.
Any thought are appreciated.
Thanks.
-Craig
Old Sep 11, 2005 | 10:00 PM
fellro86's Avatar
fellro86
My 75 had the short tailshaft with the intermediate shaft to the transfer case. A long tail will be troublesome to make work.
Old Sep 11, 2005 | 10:02 PM
ford390gashog's Avatar
ford390gashog
just swap the tailshafts you want the short one. is your t case divorced?
Old Sep 12, 2005 | 07:20 AM
cdorroh's Avatar
cdorroh
Yeah, the t-case is divorced. I've got my choice of trannys to choose from, so I may as well pick up a short tailshaft tranny to begin with, if that's what I should have...
-Craig
Old Sep 12, 2005 | 12:22 PM
fastbigblockford's Avatar
fastbigblockford
me personally, im going to use a C6 from a highboy when i change mine over, just look for any F250 4x4 up to '76.
later
Dan
Old Sep 12, 2005 | 02:30 PM
cdorroh's Avatar
cdorroh
fastbigblockford...
I have NEVER seen a '67-'77 F250 4x4 in ANY junkyards in or around Denver. (I've seen a couple that might belong in the junkyard, but...)
-Craig
Old Sep 12, 2005 | 03:05 PM
fastbigblockford
do you know anyone else in your area that runs those trucks?? i have NEVER seen a highboy in the JY either, and thank goodness for that! look around for someone that runs those trucks, heck just take a drive in the country(not sure if you live in the country or city so just an example) and look for a highboy sittin in someone's backyard/field/barn. alot of those trucks ended up farm trucks and such, so just keep an eye open...and fwiw, most of the automatic highboys i have seen were fulltime 4wd(look for one with flanged front axles and a 203 case)
hope this helps
later
Dan
Old Sep 12, 2005 | 10:50 PM
Ford_Six's Avatar
Ford_Six
The highboys used the same tailshaft as the fixed yoke long bed pickup, as far as I know. Just get one and the driveshaft from a 4x4, then you know you have the right combo for yours.
