Timing?
Old Aug 12, 2002 | 12:26 PM
4trax's Avatar
4trax
Timing?
Thanks for the help guys. Now for another qeustion,where do you guys say a stock 460 is to be timed? I'd say at 12'degrees but what are your suggestions? I have a cam(duration @ 50' INT.214 EXH.224/ LIFT INT.518 EXH.544) in it and Flat top pistons and some other goodies where would ya start inital timing?
PSYCHO 1977 F-250 4x4 472cid race truck,PSYCHO2 19771/2 F-250 4x4 472cid and goodies to go with it!!!,1987 Mustang GT 5.0 H.O. SNAKEY2. 1988 Mustang LX 5.0 H.O. Spectator Eliminator!
Old Aug 12, 2002 | 01:25 PM
Big Bad 1Ton's Avatar
Big Bad 1Ton
Timing?
timing is 10 but i have mine set at 8 because with the factory 10 i seen to have to much total timing. It like the 8 better than the 10
Old Aug 12, 2002 | 01:26 PM
bigblue's Avatar
bigblue
Timing?
Who cares what the initial timing is at. You never drive it at idle. set the timing so that at 3500 rpm it is running at 36deg. The only real problem with doing this is that the timing marks don't go this high. You will have to get a timing light that will advance electronicly.
Old Aug 12, 2002 | 02:21 PM
4trax's Avatar
4trax
Timing?
I currently have the base set at 15' and adv. set 34 at 3000rpms (the cam calls for 36 just being cautious) the base does matter because how it starts hot. I also have the vac adv. plugged into the passenger side of the 750 edel. carb so the adv. comes in later but I did have it plugged into full vac side of carb which it seemed alot more responsive and snappier off the line does that make any sense? but everybody says not to and to plug it into passenger side so i did. Whats wrong with driver side full vac adv side? will it hurt any thing? Not worried about gas mileage just performance
Old Aug 12, 2002 | 03:20 PM
Big Bad 1Ton
Timing?
flareside_thunder
Oct 15, 2007 04:37 AM
4trax
Aug 29, 2002 03:42 AM
4trax
Aug 28, 2002 10:55 PM
4trax
Aug 23, 2002 09:55 PM
4trax
Aug 14, 2002 09:16 AM
