Installing coil
Old Jul 26, 2002 | 12:43 PM
TheWiz427's Avatar
TheWiz427
Installing coil
Old Aug 12, 2002 | 02:37 PM
TailGater_73F100's Avatar
TailGater_73F100
Installing coil
Where is the best place to install coil.
The person who had the truck before had it mounted on a AC compressor which I have taken out. ( looked like chit ) now i need a place to mount it @
Thanks ya'll
Tailgater_73F100
73' F100 Custom LB w/302
Old Aug 12, 2002 | 03:20 PM
Big Bad 1Ton's Avatar
Big Bad 1Ton
Installing coil
wherever the wire will reach to. just not on the exhaust manifold though
Old Aug 12, 2002 | 03:21 PM
dfisher1's Avatar
dfisher1
Installing coil
T,
If I've removed the AC, then I mount the coil right against the head where the AC use to be. I mount it vertical as close to the distributor as possible. If you get off road you'll should mount your coil nose down so as not to collect any water.
KingFisher
