All crossmembers the same?
Old Sep 10, 2005 | 10:11 PM
redneckgirl's Avatar
redneckgirl
I was wondering if the crossmember under a '74 F250 with FE big block or 460 w/ auto is the same throughout the 70's F250 or F350 models (except 4x4)? I have one out of a '76 F350 crew cab to replace the one in mine (misplaced). Is this the same as what came in it? The crew cab was a 390 4spd. Also, I need to drill the two back holes out for the upper bolts (under the cab floor) on the frame. Shouldn't these holes be there already or is the crossmember wrong? Or did it not get drilled from the factory like it should have been? Thanks for any info!
Old Sep 10, 2005 | 11:09 PM
ford390gashog's Avatar
ford390gashog
which crossmember?
Old Sep 11, 2005 | 09:19 AM
redneckgirl
Woops...............the one under where the tranny and motor meet. It also bolts to the radius arm mounts on each side (2wd).
GreatNorthWoods
40
Feb 20, 2020 06:07 PM
Supercouper
Dec 20, 2010 07:19 PM
kwhite629
Dec 20, 2010 04:56 PM
jwrboss302
Nov 24, 2004 07:42 PM
