Can a neutral safety switch prevent spark, but allow cranking of the engine?
I swapped a 1970 f-100 body to a 76 f-250 frame. Now i have a 360/4speed instead of a 240/auto. anyway, the 360 ran great before the swap, but now cranks with no spark. I'm using the 76 wiring harness, but just have it slaved in(all the engine stuff is hooked up, but not the lights, interior stuff, etc.)
I got a diagram and checked my wiring between the ignition module, dizzy, coil, and relay. Any suggestions? yes, i've searched too :-)
thanks a ton
to clarify, the entire duraspark II system is the stock 76 for the 360 ci motor.
i do have correct voltages on the red and white wires. a guy here at work said he had a problem with not getting power to the distributor, so i'll chefck that out tomarrow. Thanks for the help Brian
Thanks everyone again. I ended up getting odd ohm readings, so i shook the harness. Bad, Bad, Bad. 30 years is hard on wiring. I ended up using that diagram above and re-wiring the engine with a new pickup in the dist and new ignition module. Runs like a champ.
Thanks for the info.
Brian
BTW-Whats the best places you've found for wiring diagrams. I'm used to aircraft tech data(active duty Air Force), so the chilton diagrams leave a little to be desired to say the least. Haynes is good on my 76 280z, but not so good on these trucks.
