Sponsored by: Real Truck
Tire air pressure???
Old Sep 9, 2005 | 10:32 AM
blankman's Avatar
blankman
Question Tire air pressure???
I am in sales and drive my 05 F-250 as my travel vehicle. I was told to run 50-55 psi for a better ride. Could this effect my mileage? Or should I go back to recommended 75-80 psi? Thanks guys!
Old Sep 9, 2005 | 11:15 AM
Antacus's Avatar
Antacus
It sure could. I noticed when I got my truck, and after the first free service the dealership inflated the rear to 75 and the front to 65. This last time I rotated my tires I was in a hurry and forgot to lower the fronts/raise the backs... rode a lot different then I was used to for that night. The chalk test is suggested to find the best psi for mpg. Put a line on the tire, run a short distance and look at the chalk line on the tire. You can see where it rubs off if you need to add or remove air.
Old Sep 9, 2005 | 12:04 PM
DZari's Avatar
DZari
I wouldn't run your tires at 75-80. I believe that pressure is used when the truck is loaded to its' max weight rating. The chalk test is a good indicator but does not take into account centrifugal elongation when the tires are spinning at highway speeds. Just my $.02. I am far from being a tire expert.
Old Sep 9, 2005 | 10:15 PM
AerostarTrailHiker's Avatar
AerostarTrailHiker
I have my F350 set at the standard settings of 65 front / 75 rear. The ride is fine. I wouldn't want a mushy ride.
betrayz
May 27, 2012 01:52 PM
XBAJBUSX
Aug 22, 2010 11:00 AM
Eng1Driver
Feb 19, 2008 11:46 AM
mac_91
1978 - 1996 Big Bronco
Nov 22, 2007 07:31 PM
macman85602
Dec 7, 2003 10:57 PM
