Sponsored by: Real Truck
Keep breaking center pins
Old Sep 7, 2005 | 06:59 AM
Big Red F250 SD's Avatar
Big Red F250 SD
Cool Keep breaking center pins
OK, this will be the 3rd time I've replaced the pins, last time was about 2 1/2 months ago. The pins that keep the axle centered on the leak springs, anyone have an idea why I keep breaking them? I don't haul any really heavy loads, and I only trailer a small flats boat or a utility trailer. .....I'm getting fed up.
thanks for any help
Old Sep 7, 2005 | 07:33 AM
BFR250SD's Avatar
BFR250SD
Only thing I can think of is too much axle wrap. Either that or cheap pins, make sure they are grade 8 or better.
How big are the blocks you are using?
Are all your spring keepers in place and are all the u-bolts torqued properly?
I'm fishing here, would be easier with some pics.
Old Sep 7, 2005 | 07:49 AM
Big Red F250 SD
the last time I replaced the bolts, I went up to Home Depot and got some hardened steel bolts. Maybe that's the problem.
As far as blocks go, I've got 2 of the stock F-250 blocks stacked on each side, so it's a total of about 3.5-4"
Spring keepers are all OK, and the U-bolts are torqued down.
Old Sep 7, 2005 | 07:52 AM
BFR250SD's Avatar
BFR250SD
They may be hardened, but make sure they are grade 8 at least. Grade 5's will come apart on you.
The stacked blocks don't help either. I've never been a real big fan of that.
I would start with the bolts and if you can, get some single 350 blocks. They are 4". The SD's are prone to axle wrap with lift. It can be a pain.
Old Sep 7, 2005 | 07:53 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That's very strange...
If the u-bolts are torqued down correctly, the friction between the leaf and the axle will keep it from moving anywhere. Those pins are really just for locating the axle before you get the u-bolts tightened, they shouldn't see any load under normal conditions.
Did you use NEW u-bolts or re-use the old ones?
Since the F350's used 4" blocks, I don't think that's the problem, although stacking two 2" blocks doesn't help the u-bolt tension.
The only other thing I can think of is, did you put other leafs in the spring pack that have more arc than the rest?
Old Sep 7, 2005 | 08:11 AM
Big Red F250 SD
thanks for the help guys. I'm starting to think the bolts I used might be the problem. I have no idea if they were grade 8, so they probably were not. The blocks used to be welded together, but have since come apart. I'll try to come up with some F-350 blocks to stick in there. The U-bolts were new with the lift (45k miles ago), but they're still in good shape.
it's gotta be the bolts/pins.
Old Sep 7, 2005 | 10:32 AM
krewat's Avatar
krewat
Uh, if that's the case, the whole u-bolted assembly is flexing - otherwise, the welds wouldn't break.
I would seriously look at the u-bolts, and make sure they are thick enough (and strong enough) to keep everything together.
Something doesn't sound right.
By the way, I used a grade 3 piece of threaded rod once, for the leaf spring pin, on my '74 highboy, never broke it, and that thing went four wheeling though lots of hard stuff. There shouldn't be so much flex there that the bolt would break.
Seriously, those U-bolts are VERY suspect...
Maybe the spring perch is not perfectly flat... that wouldn't help, especially if it's been flexing enough to break the pin and the welds on those blocks.
Or, you're beating the heck out of it
Old Sep 9, 2005 | 12:51 PM
Big Red F250 SD
update: The problem was a loose nut on a U-bolt on each side, that allowed axle flex ~~ broken center pins. I really had them torqued down w/ an impact wrench too. This time, I took a torque wrench to them after the impact wrench, so hopefully they'll stay tight. thanks for your help again
Old Sep 9, 2005 | 01:21 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
The actual recommended torque for NEW u-bolts isn't much more than 120 ft.lbs. Any more than that and you permanently deform the u-bolt, thus rendering it useless as it will stretch.
Use new u-bolts, new nuts, and 120-130 ft.lbs. TOPS.
Cody
Old Sep 9, 2005 | 06:57 PM
99f350sd's Avatar
99f350sd
Krewat is right on. Those bolts don't do much after the u bolts are tight .
Grade 8 is not neccessary. There's little stress on the bolts. The u bolts do all the work . Make sure the ubolts are tightened evenly or you will find one loose also check them after you have driven the truck for awhile. Don't use welded blocks and no higher than the f350 units. The only way the bolts will break is to have really loose u bolts.
Dick
Old Sep 9, 2005 | 10:45 PM
02superstroker's Avatar
02superstroker
I believe the ford specs for rear u-bolt torque is 99. Not 100% sure but i think thats right.
1L243
All Things Towing
21
Feb 3, 2015 02:52 PM
Donzi Dude
Sep 18, 2014 11:47 AM
talonpilot
2009 - 2014 F150
Feb 19, 2014 07:24 PM
robert_l_ross
Aug 26, 2012 12:56 AM
camano
Electrical Systems/Wiring
Nov 17, 2006 04:40 PM
