Sponsored by: Auxito
What a difference!
Old Sep 8, 2005 | 04:38 PM
xtrford's Avatar
xtrford
Thumbs up What a difference!
I cant believe what a difference a new fuel filter can make, idle comes down nicely and accelleration is more refine. I could hardly breath through the old filter, it was pretty clogged. What is the proper change interval for fuel filters by the way?
Old Sep 8, 2005 | 04:54 PM
code_red's Avatar
code_red
Every 15,000 miles or 12 months, whichever comes 1st
Old Sep 11, 2005 | 02:15 PM
bigdaddyII's Avatar
bigdaddyII
Where was your fuel filter located? I have been wanting to change mine for a while now.
Old Sep 11, 2005 | 02:19 PM
ford390gashog's Avatar
ford390gashog
its along the frame rail. you need a fuel filter tool. which is about 10.00 for the good one or 5.00 for the cheap palstic one.
Old Sep 11, 2005 | 05:23 PM
bigdaddyII's Avatar
bigdaddyII
WHAT???? A fuel filter tool? For what? I dont think I have ever had to use a "fuel filter tool" to change a fuel filter before in my life.
Old Sep 11, 2005 | 05:35 PM
holiday187's Avatar
holiday187
sorry but for the ford fuel filter you need a fuel filter tool. when i had a gmc truck it was just a wrench i needed
Old Sep 11, 2005 | 05:39 PM
preppypyro's Avatar
preppypyro
I'm curious, what does the fuel filter tool look like? Sucks that a guy has to buy one just to change it too eh!
steve(ill)'s Avatar
steve(ill)
filter is on the framr rail under drivers seat. the fuel line has snap on plastic ends that press onto the new filter inlet and outlet. it has sheetmetal ears inside. if you pry it off, it will work, but the ears are used as retainers. you get the plastic sleeve at Auto Zone, slip over the line and push the sheetmetal ears out of the way as you slide the filter out. Same setup used on the new air conditioner ends, etc.
bigdaddyII's Avatar
bigdaddyII
What I mean is, what is the purpose of the tool? What special bracket or what not needs to be removed with it? From my understanding the only thing holding these filters on are plastic clips, which I was provided with on the new filter.
Old Sep 11, 2005 | 05:45 PM
LxMan1's Avatar
LxMan1
The tool releases the clips from the filter. The clips are in the lines and snap over a barb on the filter. The tool pushes into the fitting to release the clip from the barb so that the line can be pulled off.
Old Sep 11, 2005 | 06:02 PM
ford390gashog
also the clips are part of the lines so if you break them you have to buy a whole new line which is over 200.00 . don't try to use something else to remove them.
Old Sep 11, 2005 | 11:09 PM
paul812's Avatar
paul812
yes there are 2 types,,,the "older" type with EXTERNAL visable plastic clips you just pull out with pliers. and a new filter should come with new ones. I think there color coded for 5/16 and 3/8 line size. The "newer" style , not sure what yr but my '01 has it, doesnot use the plastic clips , you have to buy the special insertion "tool" that releases the internal metal clips, as someone has mentioned. In my opinion, the older style worked just fine. of course ford has brighter idea.....paul
Old Sep 12, 2005 | 08:35 AM
berkad's Avatar
berkad
How are you relieving the fuel pressure prior to removal?
Old Sep 12, 2005 | 09:27 AM
xtrford's Avatar
xtrford
First disconnect the neg battery post, then unscrew the schrader valve located on top of the feul rail on passenger side of engine. Make sure you have a rag to soak up the feul that will leak out so it does not spill down into a sparkplug hole. I also recommend an old coffee can to catch any feul that will run out from the feul filter when you disconnect it from the feul lines. I never lost any feul from the tank line, but gravity pushed most of the feul from the engine line, all together I lost about 1/2 cup full, not a whole lot I dont think.
Old Sep 12, 2005 | 04:49 PM
code_red's Avatar
code_red
heres a picture of what the tool looks like. This one is the high dollar one. Its a red coated 5/16 . This is the one i use to remove my fuel filter on a 97 F150 4x4 flareside 4.6
