I need to replace the seals on the inside and outside of the doors on the windows. Does anyone know a source for these and also how about how to change them out?
I am trying to get my truck completely road worthy.
Check our sponsors on the left. I would try to find the best ones available. As I recall I was able to replace mine without removing the window. Some small screws on on side and clips on the other.
I replaced all of mine also. Including the windwing. What a pain that was ! The channels and felt were not to difficult, and if you have good mechanical skills you can see how it all works ( a Chiltons or other Hayes manual helps a lot on stuff like this!) You have to take the windwing frame out of the door (which is also the front channel of the main window inside the door) to replace the seals. I got my OEM NOS seals on eBay, but I see them in the JC Whitney catalog (not NOS) also.
Good luck!
Dak
I wish I could get to that site but for some reason it's blocked here at work.
Good luck!
Dak
I'll have to get one (JC Whitney catalog) on the way home.
