Sponsored by: Real Truck
Front and rear axles
Old Sep 7, 2005 | 12:43 PM
Commandohorn's Avatar
Commandohorn
What axles are in a 2001 F250 CC 4X4 SB? Dana front and Ford rear? Which models of each? Thanks, couldn't find anything when I searched.
Old Sep 7, 2005 | 01:25 PM
vwp6269's Avatar
vwp6269
Usually its a dana 50 in front and a sterling 10.25" in the back. But you may have ended up with a Dana 60 like i did in front of my F350 CC SRW. which only comes on duallys they say. If you are going to be doing some gearing run the axle id through ford parts department and let the tell you exactly what it is. They look the same to the naked eye.
Old Sep 10, 2005 | 02:56 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You have a Dana 50 front axle with 3.73 gears and an open differential. The Rear is a 10.5", 3.73 LS.
Old Sep 12, 2005 | 10:15 AM
Commandohorn
Front and Rear Axles
Thanks for the info. That limited slip is just that...it slips real easy with limited effort!!! Didn't help a bit on the boat ramp the other day!
Old Sep 12, 2005 | 08:28 PM
none2's Avatar
none2
https://www.ford-trucks.com/forums/s...d.php?t=404095
FORDMAN F2011
May 3, 2011 05:15 PM
CowboyFromHell
23
Feb 25, 2009 08:37 AM
bigtexan99
All Things Towing
17
Feb 12, 2007 01:49 PM
Project_MudXJ
1983 - 2012 Ranger & B-Series
Sep 5, 2005 10:46 AM
rustyolred27
May 16, 2003 07:00 PM
