More recalls
Old Sep 7, 2005 | 12:03 PM
fordman15's Avatar
fordman15
More recalls
The affected vehicles include: 1994-2002 model F-150s, 1997-2002 Expeditions, 1998-2002 Navigators and 1994-1996 Broncos equipped with factory-installed speed control.
Old Sep 7, 2005 | 12:06 PM
01silvergt's Avatar
01silvergt
Can you please provide an article on this?
Old Sep 7, 2005 | 12:17 PM
fordman15's Avatar
fordman15
http://news.yahoo.com/s/ap/20050907/...ge/ford_recall
Old Sep 7, 2005 | 12:22 PM
01silvergt's Avatar
01silvergt
Thanks!
Old Sep 7, 2005 | 12:41 PM
amm888's Avatar
amm888
so what do you do to get this recall (i've never done one before), can i just take my 97 expy to any ford dealer to have them install the fix?
Old Sep 7, 2005 | 12:43 PM
01silvergt's Avatar
01silvergt
You should get a notice in the mail from Ford. When you get this call the local dealer to set an appt. to go in and get it fixed. The appt. thing is really used for dealers that will get a lot of people, if yours is small you can probably just go in, but I would still call to make sure they have the parts.
Old Sep 7, 2005 | 12:47 PM
amm888's Avatar
amm888
i don't think ford has me on record. i bought the truck about a year ago from a private seller.
Old Sep 7, 2005 | 12:48 PM
01silvergt's Avatar
01silvergt
If you registered it with the county / State (license plate/inspection/tags), then they have you on record.
Old Sep 7, 2005 | 12:57 PM
kitsinian's Avatar
kitsinian
Does anyone know where the thread is that listed ALL the vehicles that have this poorly designed cruise control switch. I seem to remember that my 2003 Expedition may or may not have the switch but I don't know how to determine if it does so I can complain to Ford that it needs to be covered in the recall also.
Thanks
Old Sep 7, 2005 | 01:10 PM
JayS's Avatar
JayS
Didn't they replace the entire switch when they did the recalls on the 2000 models? Looking at mine, that had the recall done, it appears I have a new switch.
http://www.cnn.com/2005/AUTOS/09/07/...all/index.html
What I'm wondering is if have the fuse in there that this new recall is doing might be safer.
Old Sep 7, 2005 | 01:16 PM
01silvergt's Avatar
01silvergt
http://www.cnn.com/2005/AUTOS/09/07/ford_recall/index.html
I bet this is just a continuation of your recall.
Old Sep 7, 2005 | 01:48 PM
2000ExpXLT's Avatar
2000ExpXLT
I happened to have my Exp at the dealer yesterday for an unrelated problem and they fixed the brake fluid/cruise control recall (which is I hadn't heard about until today) and the switch recall (which I was aware of). They're both separate recalls issues.
The old recall was just a bad switch that could malfunction and catch fire from overheating (if I recall correctly).
The latest issue is where the brake fluid can drip on the cruise control mechanizm and cause a fire. I didn't look to see what they replaced.
Old Sep 7, 2005 | 01:56 PM
01silvergt's Avatar
01silvergt
They are both the same recall. The CC switch on the master cylinder can leak brake fluid, thus causing a fire.
Old Sep 7, 2005 | 03:26 PM
ms6073's Avatar
ms6073
Rats, I did not want to take any chances and already and retrofitted the effected switch nearly two-months ago.
Old Sep 7, 2005 | 03:29 PM
01silvergt's Avatar
01silvergt
Did you buy the "fixed" switch from Ford? If so you can get your money back.
